Trav012000 |
Member ![]() ![]() Group: Members Posts: 59 Joined: 23-September 08 From: Indiana, USA Member No.: 9,583 Region Association: Upper MidWest ![]() |
Okay so it took me awhile but I finally got my rear droplink bushings pressed into the droplinks. Now I'm trying to get the droplinks attached to the car. Does anyone have a magical way of making this happen? '76 model year if it matters. (IMG:style_emoticons/default/smile.gif)
Thanks guys. |
Cupomeat |
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region ![]() |
Hmmm, I think I had the exact same questions but I can't find the thread.
The answer appears to be the largest channel locks you can find, or a wooden drift and a big hammer. Hope that helps. |
Trav012000 |
Hmmm, I think I had the exact same questions but I can't find the thread. The answer appears to be the largest channel locks you can find, or a wooden drift and a big hammer. Hope that helps. Apparently I didnt try my channel locks quite hard enough. (IMG:style_emoticons/default/biggrin.gif) |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
When I did mine, I used a large C-clamp. Worked well, just had to keep it aligned or it wanted to slip off. Lubed them up also.
Tom |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
BFH...I use a rubber one.
A very well placed very powerful hit will do it. Rich |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Big channel locks
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
A "squeeze to tighten" bar clamp. Use a jack to move one trailing arm or the other upward to get the ball on the arm lined up with the socket in the drop-link.
I've also used a C-clamp, but it was hard to keep lined up correctly while tightening the clamp. --DD |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,104 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
I have heard that drilling a small hole threw the back of the bushing lets the air out and makes it easier so you are not compressing air too...
dgw |
Dennis Winter ![]() ![]() ![]() Group: Members Posts: 562 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California ![]() |
A "squeeze to tighten" bar clamp. Use a jack to move one trailing arm or the other upward to get the ball on the arm lined up with the socket in the drop-link. I've also used a C-clamp, but it was hard to keep lined up correctly while tightening the clamp. --DD the bar clamp worked well for me also. I could not make it work with a C clamp, hammer, etc. |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Channel locks on the sway bar side
Hammer on the control arm side |
rascobo |
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest ![]() |
I have heard that drilling a small hole threw the back of the bushing lets the air out and makes it easier so you are not compressing air too... (IMG:style_emoticons/default/agree.gif) It's how I've been doing mine for years. It makes them much easier to get on, and haven't found any drawbacks. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,258 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
When I did mine, I used a large C-clamp. Worked well, just had to keep it aligned or it wanted to slip off. (IMG:style_emoticons/default/agree.gif) |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Seems like adding a hole would help but it also would make it easier for crud to migrate through the bushing.
Trav012000 |
Channel Locks worked guys thanks. Clamps would have been better. And I thought about drilling a hole. Would have helped too, I apparently squeezed so hard 3 of my fingers ended up bleeding from the cuticle. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 18th July 2025 - 07:59 PM |
