Full Version: Pressing on Rear Droplinks
Trav012000
Okay so it took me awhile but I finally got my rear droplink bushings pressed into the droplinks. Now I'm trying to get the droplinks attached to the car. Does anyone have a magical way of making this happen? '76 model year if it matters. smile.gif
Thanks guys.
Cupomeat
Hmmm, I think I had the exact same questions but I can't find the thread.
The answer appears to be the largest channel locks you can find, or a wooden drift and a big hammer.
Hope that helps.
Trav012000
QUOTE(Cupomeat @ Apr 24 2009, 04:52 PM) *
Hope that helps.
Tom
When I did mine, I used a large C-clamp. Worked well, just had to keep it aligned or it wanted to slip off. Lubed them up also.
Tom
r_towle
BFH...I use a rubber one.
A very well placed very powerful hit will do it.
Rich
SLITS
Big channel locks
Dave_Darling
A "squeeze to tighten" bar clamp. Use a jack to move one trailing arm or the other upward to get the ball on the arm lined up with the socket in the drop-link.
I've also used a C-clamp, but it was hard to keep lined up correctly while tightening the clamp.
--DD
ConeDodger
I have heard that drilling a small hole threw the back of the bushing lets the air out and makes it easier so you are not compressing air too...
dgw
QUOTE(Dave_Darling @ Apr 24 2009, 07:53 PM) *
--DD
the bar clamp worked well for me also. I could not make it work with a C clamp, hammer, etc.
Joe Ricard
Channel locks on the sway bar side
Hammer on the control arm side
rascobo
QUOTE(ConeDodger @ Apr 24 2009, 10:43 PM) *
It's how I've been doing mine for years. It makes them much easier to get on, and haven't found any drawbacks.
QUOTE(Tom @ Apr 24 2009, 03:38 PM) *
charliew
Seems like adding a hole would help but it also would make it easier for crud to migrate through the bushing.
Trav012000
Channel Locks worked guys thanks. Clamps would have been better. And I thought about drilling a hole. Would have helped too, I apparently squeezed so hard 3 of my fingers ended up bleeding from the cuticle. smile.gif
