jcambo7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,691 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest ![]() |
How does the fuel gauge get the reading from the float sensor? Are there wires involved going from the sensor to the gauge? (IMG:style_emoticons/default/confused24.gif)
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Bluetooth. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif)
(IMG:style_emoticons/default/poke.gif) There are wires from the sender to the gauge. The sender is variable resistance and the gauge is basically an ohm-meter. So as the fuel level rises or falls, the resistance changes and that change in resistance is displayed by the gauge. |
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
jcambo7 |
Bluetooth. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/poke.gif) There are wires from the sender to the gauge. The sender is variable resistance and the gauge is basically an ohm-meter. So as the fuel level rises or falls, the resistance changes and that change in resistance is displayed by the gauge. Thanks for the (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/av-943.gif) Very funny. Well I guess I need the wires for that. Cuz I can't find any wires for the float sensor. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,201 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
jcambo7 |
Cuz I can't find any wires for the float sensor. So on there aren't any wires on the passenger side of your gas tank? If not, the connector has dropped behind the gas tank. Got a pic? Here is a pic but I am postive I didn't see any wires with connectors on them? (IMG:style_emoticons/default/confused24.gif) ![]() |
McMark |
Look on the passenger's side of the airbox, up higher than your picture shows.
jcambo7 |
McMark |
Look here. Could be tucked behind the airbox.
Attached image(s) ![]() |
McMark |
Here's what the connector looks like. Square box.
jcambo7 |
Here's what the connector looks like. Square box. All right. Thanks a lot for showing me pics of where it might be and what it looks like. I will definitely check in that area and look for it. Hopefully it is there. It should cuz I c no reason for it not to be there. |
jcambo7 |
I found it. Thank you everyone for the help. (IMG:style_emoticons/default/drunk.gif)
Lo-Fi Version | Time is now: 30th July 2025 - 06:07 PM |
