What r these? |
What r these? |
jcambo7 |
Apr 25 2009, 08:35 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
So I found these in my car. Can't figure out what exactly they are. Help please on what they r and where they go.
Here's a couple of pics. |
jonferns |
Apr 25 2009, 08:42 PM
Well, looks like we have some sort of bushings here. Beyond that I can't be of much help, but they look familiar and im also curious.
Wes V |
Apr 25 2009, 08:45 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
My guess would be that they are the parts required to rebuild a pedal assembly.
Wes |
cwpeden |
Pedal cluster bushing set. The roll pin is for the clutch pedal.
jcambo7 |
Apr 25 2009, 08:47 PM
Pedal cluster bushing set. The roll pin is for the clutch pedal. Thanks every one. (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/beerchug.gif) |
cwpeden |
Apr 25 2009, 08:53 PM
You may want to do a search on the cluster rebuild. I know there is one on Pelican and there must be one here.
There have been many solutions to the roll pin removal problem, cause it can be a @!%$!$@#$! sometimes. Just dont be tempted by the 'bigger hammer' solution too fast. |
jcambo7 |
Apr 25 2009, 09:08 PM
You may want to do a search on the cluster rebuild. I know there is one on Pelican and there must be one here. There have been many solutions to the roll pin removal problem, cause it can be a @!%$!$@#$! sometimes. Just dont be tempted by the 'bigger hammer' solution too fast. Thanks for the info. I dont c any reason to replace them right now. The pedals all seem to be moving just fine. |
ConeDodger |
Apr 26 2009, 07:14 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
You may want to do a search on the cluster rebuild. I know there is one on Pelican and there must be one here. There have been many solutions to the roll pin removal problem, cause it can be a @!%$!$@#$! sometimes. Just dont be tempted by the 'bigger hammer' solution too fast. Thanks for the info. I dont c any reason to replace them right now. The pedals all seem to be moving just fine. Still, it is suspicious that you would have a peddle rebuild kit in the car if it didn't need it. Do two simple tests. Push the brake peddle down and make sure it freely returns and, pull up the carpet and look for brake fluid in the area of the peddle cluster. It will look wet. Ever notice your brake lights on when you are not pushing on the brake peddle? It could be that the PO bought the rebuild parts and then decided that just buying a rebuilt cluster from Bruce Stone was easier. |
Cap'n Krusty |
Apr 26 2009, 08:37 AM
This is e-mail. You're allowed to spell out words, even 3 letter ones ...........
The Cap'n |
jcambo7 |
Apr 26 2009, 09:09 AM
You may want to do a search on the cluster rebuild. I know there is one on Pelican and there must be one here. There have been many solutions to the roll pin removal problem, cause it can be a @!%$!$@#$! sometimes. Just dont be tempted by the 'bigger hammer' solution too fast. Thanks for the info. I dont c any reason to replace them right now. The pedals all seem to be moving just fine. Still, it is suspicious that you would have a peddle rebuild kit in the car if it didn't need it. Do two simple tests. Push the brake peddle down and make sure it freely returns and, pull up the carpet and look for brake fluid in the area of the peddle cluster. It will look wet. Ever notice your brake lights on when you are not pushing on the brake peddle? It could be that the PO bought the rebuild parts and then decided that just buying a rebuilt cluster from Bruce Stone was easier. Brake pedal travel is fine, no brake fluid on the floor, and brake lights only come on when pressure is applied to brakes. |
jcambo7 |
Apr 26 2009, 09:11 AM
This is e-mail. You're allowed to spell out words, even 3 letter ones ........... The Cap'n (IMG:style_emoticons/default/av-943.gif) Oh...I thought this was a forum...and I didn't realize their is a rule on english here (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) |
CliffBraun |
Apr 26 2009, 10:55 AM
Member Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
This is e-mail. You're allowed to spell out words, even 3 letter ones ........... The Cap'n (IMG:style_emoticons/default/av-943.gif) Oh...I thought this was a forum...and I didn't realize their is a rule on english here (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) Well, this is a forum, there aren't rules on english here, but it's best not to make people's eyes bleed when they read your post. |
MDG |
Apr 26 2009, 11:37 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
If you do end up re-building the pedal cluster, there's an excellent write up in the Classics by Eric Shea. I used it as reference when I did mine last week - easy peasy.
jcambo7 |
Apr 26 2009, 12:08 PM
If you do end up re-building the pedal cluster, there's an excellent write up in the Classics by Eric Shea. I used it as reference when I did mine last week - easy peasy. Thanks for the info. I will remember to look it up if and when I do replace them. Appreciate it. |
McMark |
Apr 26 2009, 12:26 PM
Throw that roll pin in the trash, NOW!!!
jcambo7 |
Apr 26 2009, 12:57 PM
Throw that roll pin in the trash, NOW!!! Um...just wondering why? (IMG:style_emoticons/default/confused24.gif) |
Rav914 |
Apr 26 2009, 02:28 PM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Cap'n Krusty |
Apr 26 2009, 02:50 PM
Oh? I've never had a "fit" problem with the replacement pins. Of course, I've only been working on 914s on a regular basis for 36 years .......................... The Cap'n |
McMark |
Apr 26 2009, 03:28 PM
That pin is a C shape. The stock roll pin is rolled over and over for strength. Those 'C' roll pins can shear after use and leave you stranded. Some of the kits (newer? different manufacturer?) have a rolled pin which is suitable. Yours is clearly not.
sww914 |
Apr 26 2009, 07:25 PM
Lo-Fi Version | Time is now: 16th May 2024 - 03:00 AM |
