possible oil starvation when driving., noticed this at Hershey.. Help! |
ChrisFoley |
Apr 26 2009, 09:37 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
ChrisFoley |
Apr 26 2009, 09:51 PM
"so who didnt develop a car problem at hershey.?? guy next to me noticed his rear wheels were both rubbing. i noticed my car dosnt want to start anymore zach has a oil starvation problem the white car (apon arrival) was grindin and smelling very clutchy anyone eles?? blink.gif and i thought it was just me" Drove to Hershey Saturday morning (200 miles) with Ray, Rich, Tim, Chris Foley, Jeff, and Jerry. When we left the Palmirya Hotel to head out to Hershey Saturday morning. My car didn't want to start right up. It took a few cranks but I got her started. Tim's tangerine 1.7 wouldn't start either. Jeff lent a hand with a Quarter. Damn she started right up (IMG:style_emoticons/default/aktion035.gif) Got to fix that hot start problem. Other than that drove about 400 miles this weekend no major problems (IMG:style_emoticons/default/w00t.gif) Scott 73 2.0 My 1.8 ran flawlessly. (IMG:style_emoticons/default/bootyshake.gif) 70mph average speed over 300 mile return trip distance, 185 degree peak oil temp, 86mph peak speed somewhere on the Merritt Parkway in CT, 25+ mpg with about 1000 miles on the engine. Just over 3400rpm at 75mph. (IMG:style_emoticons/default/driving.gif) I have never driven a 914 that far before. (IMG:style_emoticons/default/biggrin.gif) 4 hours 15 minutes non-stop except for a quick pee break I love the sound of my Tangerine Exhaust, especially with the window down. Sweet music! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/laugh.gif) The dual 40 Dellortos are a bit loud though. (IMG:style_emoticons/default/beer.gif) Oh, that was Ed with the quarter on your starter. |
yeahmag |
Apr 26 2009, 10:12 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
An easy and surefire way to check is to remove the oil filter and see if it pumps oil out. If it doesn't you broke the tang off your pump. Did you get this from Jake? Was it all ready clearanced?
VaccaRabite |
Apr 27 2009, 06:20 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
An easy and surefire way to check is to remove the oil filter and see if it pumps oil out. If it doesn't you broke the tang off your pump. Did you get this from Jake? Was it all ready clearanced? Maybe? The guy I bought the engine from got some parts from Jake, some parts from other places. When I pull it (maybe this weekend if I can wrangle time) I'll find out what I am looking it. I wanted to pull the exhaust off for ceramic coating anyhow after the MEI. Zach |
yeahmag |
Apr 27 2009, 11:22 AM
No need to pull it for this test. Just spin off the oil filter and crank it over with a drain pan and the coil wire removed.
type2man |
Apr 27 2009, 11:41 AM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
No need to pull it for this test. Just spin off the oil filter and crank it over with a drain pan and the coil wire removed. (IMG:style_emoticons/default/agree.gif) And if you see no oil coming out, do not run it anymore until you find out the problem. Your tang probably broke off the oil pump or the gear on the pump wasnt pressed in properly onto the shaft(I've seen it). I would go with a factory pump, they work great. Patrick |
Dr Evil |
Apr 27 2009, 01:25 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Happy happy joy joy (IMG:style_emoticons/default/rolleyes.gif) Do we really need to do the filter test since the oil pump is either bad or there is a monster blockage in the case? I am not a gainst a stock pump, this is a 2056 and if stock works I would support Zach using one.
yeahmag |
Apr 27 2009, 01:26 PM
I was suggesting that as a final idiot test only...
type11969 |
Apr 27 2009, 01:44 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
Zach-
I have a couple of stock pumps if you need one. I think the 30mm oil pumps are overkill too and can lead to hotter oil (saw that in my beetle), but that isn't your issue here. I also have a 30mm t1 pump floating around somewhere too that should be set up properly for a t4 if you want to stick with a 30mm unit. -Chris |
rhodyguy |
Apr 27 2009, 03:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
your sump pickup tube has the extension on it for the tuna can, correct?
VaccaRabite |
Apr 27 2009, 03:41 PM
Apr 27 2009, 03:50 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
"so who didnt develop a car problem at hershey.?? Drove to Hershey Saturday morning (200 miles) with Ray, Rich, Tim, Chris Foley, Jeff, and Jerry. When we left the Palmirya Hotel to head out to Hershey Saturday morning. My car didn't want to start right up. It took a few cranks but I got her started. Tim's tangerine 1.7 wouldn't start either. Jeff lent a hand with a Quarter. Damn she started right up (IMG:style_emoticons/default/aktion035.gif) Got to fix that hot start problem. Other than that drove about 400 miles this weekend no major problems (IMG:style_emoticons/default/w00t.gif) Scott 73 2.0 Oh, that was Ed with the quarter on your starter. That is correct Chris. Tell Ed I'm sorry about the mix up. For some reason he reminds me of a Jeff. Well thank him anyway for getting Tim's heap out of the way (IMG:style_emoticons/default/lol-2.gif) How does he do that Quarter trick anyway. Is he jumping the stater solenoid? Or is he doing something by the alternator? Just so happens Sunday night went to get into the car to pull it into the garage and the car wouldn't start. Headlights were dim. Put a meter on the battery it was testing at 12.5volts at rest. Would love to know how Ed does it. (IMG:style_emoticons/default/poke.gif) Nice driving with the two of you on the way down. Man your ass must hurt with those seats Jump large 12vdc positive battery terminal at the starter to the small yellow wire terminal on the solenoid. Rich |
Dr Evil |
Apr 27 2009, 03:54 PM
I was suggesting that as a final idiot test only... Not being down on your idea (IMG:style_emoticons/default/wink.gif) |
yeahmag |
Apr 27 2009, 05:00 PM
You almost made me cry... (IMG:style_emoticons/default/happy11.gif)
Rubber Boa |
Apr 28 2009, 10:50 PM
Newbie Group: Members Posts: 24 Joined: 9-December 07 From: Medford Or. Member No.: 8,438 |
A year ago or so I build a 2.4+ 2L 200hrp. and when I put in the big volume pump I had to grid off the input paddle because it was to long? thick can't remember. but that sucker needs a lot of oil and I have never had the problem. The man i worked with told me I would have problems if I did not do this mod. I will ask him tomorrow what we did and why.
Boa |
charliew |
Apr 29 2009, 10:58 AM
If it is the old bug deal the cam gears set at different depths inside the case, one has more dish than the other and the pumps need to match the depth so that full contact is between them. Unneeded volume (more volume is how you make more pressure) means a lot higher oil temps when the oil doesn't have anywhere to go (I think 340 df is boiling) and sometimes boiling makes air bubbles and air don't work in bearings.
VaccaRabite |
Apr 29 2009, 07:30 PM
I'm going to be buying one of Jakes cam kits tomorrow since I am splitting the case when I autopsy the engine. When I talk to him, I am going to ask him about overpressure with a 30mm pump.
Apr 29 2009, 08:17 PM
Zach,
To ensure that you learn what is going on....get a set of calipers and measure the pump...the length of the tang..the depth of the hole in the case and the depth of the tang in the camshaft. This is where the issues arise. All the pumps work in the original location....the issues happen when you use a pump designed for a type one and put it in a type 4. Its all depth related, not diameter, and not to much oil pressure. RIch |
type11969 |
Apr 29 2009, 09:04 PM
It is also possible that if the cam gear was not spotfaced for the cam bolts and the backside of the pump was clearanced instead that the shaft supporting the driven pump gear came loose and wreaked some havoc . . .
Can you pull a t1 pump from a 914 without pulling the fan housing/dropping the engine? Or the stock pump for that matter . . . -Chris |
VaccaRabite |
Apr 30 2009, 09:47 AM
It is also possible that if the cam gear was not spotfaced for the cam bolts and the backside of the pump was clearanced instead that the shaft supporting the driven pump gear came loose and wreaked some havoc . . . Can you pull a t1 pump from a 914 without pulling the fan housing/dropping the engine? Or the stock pump for that matter . . . -Chris Nope. Engine has to come down, engine bar has to be removed, and fan shroud has to come off. Zach |
Lo-Fi Version | Time is now: 31st May 2024 - 11:52 PM |
