> Intermittant idle and losing power, Fuel lines clear to the fuel filter
Trav012000
post Apr 27 2009, 01:37 PM
Awhile back I sealed my gas tank to prevent the rust flakes from getting into my fuel lines and causing this exact problem I'm about to explain.
A couple days ago I was driving her home when she felt like she was hesitating. It would still drive, it'd just hesitate if I pressed down too hard. So I came back the next morning and tried starting it up, the idle was jumping dropping every once in awhile. Now I'm to the point that if I hit the gas while parked it will rev up, then die like it's starved of fuel. The fuel pump working fine, I pulled off the fuel line on the other side of the fuel filter and the pressure looked okay.
Anyone have any suggestions. I did pick up some pistons and cylinders over the weekend that I'm hoping to put in in the next few weeks since one of mine doesnt make any compression and another only makes about half. (IMG:style_emoticons/default/headbang.gif)
Running dual webers on a 2.0L '76
underthetire
post Apr 27 2009, 01:41 PM
QUOTE(Trav012000 @ Apr 27 2009, 12:37 PM) *
you sure its the cylinders? Might be a head. I think you need to fix those problems before worrying about fuel and idle. BTW, sounds like points to me.
Trav012000
post Apr 27 2009, 01:48 PM
I'm not sure it is, no. It was recommended to me by the shop I take it to here in town. I should have mentioned it's my daily driver so getting it up and running as soon as possible will help in getting back and forth to work. (IMG:style_emoticons/default/smile.gif)
QUOTE(underthetire @ Apr 27 2009, 03:41 PM) *
Not quite sure what that means. (IMG:style_emoticons/default/smile.gif) I'm a computer guy trying to learn how to work on his 914. (IMG:style_emoticons/default/driving.gif)
underthetire
post Apr 27 2009, 02:00 PM
Points or "ignition breaker" are located in the distributor. They control spark to the spark plugs. ( yes i am over simplifying this ) If they get worn, or out of adjustment, and they always do, you need to adjust them/replace them. You will never get a good idle with a dead hole or two, no vacuum, no fuel. Now for the S-storm, Points suck, electronic is the way to go. (IMG:style_emoticons/default/poke.gif)
type2man
post Apr 27 2009, 02:14 PM
Check your idle jets, they probably are clogged. They are located on the outsides of the carbs close to where the fuel lines run into the carbs. Remove them and look at them closely to see if you have crap in there. If so, blow it out and drive it again.
Patrick
Trav012000
post Apr 27 2009, 05:11 PM
Thanks for all the help guys. Looks like type2man is the winner. Dirty idle jet on the same side of the engine as my two pistons that actually make compression. (IMG:style_emoticons/default/biggrin.gif)
After I scoured the internet looking for a diagram on where the hell the idle jet was, it was a piece of cake after that. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/type.gif)
- Lo-Fi Version Time is now: 8th November 2025 - 03:51 AM
