914-6 oil tank leaks?!@# |
xsurfer |
Apr 29 2009, 09:05 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Filth! GRIME and more. 4 hours later the area including fender well is almost clean. There was so much accumulated oil/road dirt on the tank I wonder if it added to the oil temp. I'd guess there has been no maintance around the tank since new. I don't believe the area can really be cleaned without removing the tank.
Still have quite a lot to clean. The trailing arm will need to be repainted as will the right side I'd guess. Does anyone have the paint spec or is powder coating the way to go? |
xsurfer |
Apr 29 2009, 09:18 AM
I had similar problem. O-ring under the filter console was squished, hard and useless (probably 25 years old). Strange that I've never seen a tip to change these every few years, it's easy and cheap. I replaced mine, but it could be the source. Did you use gasket sealer or just the o ring. I have an spare o ring so I'll replace that whent he tank goes back in. Gene |
mskala |
Apr 29 2009, 10:01 AM
I had similar problem. O-ring under the filter console was squished, hard and useless (probably 25 years old). Strange that I've never seen a tip to change these every few years, it's easy and cheap. I replaced mine, but it could be the source. Did you use gasket sealer or just the o ring. I have an spare o ring so I'll replace that whent he tank goes back in. Gene I used no sealer, doesn't seem like it would be useful. |
Lo-Fi Version | Time is now: 5th June 2024 - 05:09 AM |
