Which Bell Crank and Throttle Cable to use with a WEvo 915?, A 914/6 parts question |
Nana's_914 |
Apr 28 2009, 02:33 PM
Member Group: Members Posts: 98 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California |
Hi All,
I am looking around for ways to connect the throttle up on my 914/6 project. I am using a WEvo 915 and a CIS 3.0. I talked to Patrick motorsports about the cable and they sell an extremely long cable that omits the bellcrank for a little over $100. Can I use a 914/6 cable, a 914/6 bellcrank (attached at the stock spot on a 915), and a 911 linkage? What are the choices? I'd like to use a bellcrank solution if it fits. Thanks |
carr914 |
Apr 29 2009, 03:52 AM
Racer from Birth Group: Members Posts: 118,626 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I don't know, but since I have a prior relationship with your WEVO, I will give you a (IMG:style_emoticons/default/icon_bump.gif) back to page 1, so hopefully someone will have an answer for you.
T.C. |
GeorgeRud |
Apr 29 2009, 07:47 AM
When I did my conversion, I got the bellcrank from John Williamson @ Otto's in Venice, Ca. You could give him a call, or check with Auto Atlanta (or even your local Porsche dealer or Stoddard's).
brp986s |
Apr 29 2009, 07:28 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
I just checked pelican - the oem cable is gone. I got a patrick throttle cable for my wevo/915. The oem was crappy anyway.
The bigger puzzle is with the clutch cable and linkage. Have you dealt with this yet? |
Lo-Fi Version | Time is now: 15th May 2024 - 10:39 PM |
