Nana's_914
Apr 28 2009, 02:33 PM
Hi All,
I am looking around for ways to connect the throttle up on my 914/6 project. I am using a WEvo 915 and a CIS 3.0. I talked to Patrick motorsports about the cable and they sell an extremely long cable that omits the bellcrank for a little over $100. Can I use a 914/6 cable, a 914/6 bellcrank (attached at the stock spot on a 915), and a 911 linkage? What are the choices? I'd like to use a bellcrank solution if it fits.
Thanks
carr914
Apr 29 2009, 03:52 AM
I don't know, but since I have a prior relationship with your WEVO, I will give you a
back to page 1, so hopefully someone will have an answer for you.
T.C.
GeorgeRud
Apr 29 2009, 07:47 AM
When I did my conversion, I got the bellcrank from John Williamson @ Otto's in Venice, Ca. You could give him a call, or check with Auto Atlanta (or even your local Porsche dealer or Stoddard's).
brp986s
Apr 29 2009, 07:28 PM
I just checked pelican - the oem cable is gone. I got a patrick throttle cable for my wevo/915. The oem was crappy anyway.
The bigger puzzle is with the clutch cable and linkage. Have you dealt with this yet?
