Could my 1970 fuel lines be original?, Will Porsche replace them? |
Porsche Rescue |
May 3 2009, 06:14 PM
While looking at the AA catalog to find fuel hoses, I found a statement that the recall back in the day replaced the fabric covered lines with rubber lines less affected by battery acid.
My one-owner '70 (which was out of the country for much of the early 70's) has all fabric covered fuel lines and they look very old. Could it be that they were never replaced under recall? Will Porsche still honor the recall and replace my lines? I seem to remember reading something on the issue on this board but can't find it through the search feature. |
tod914 |
May 3 2009, 06:32 PM
I recall a fairly recent thread where they will. You need to check your vin with their database to see if it's been done or not. Sorry but I don't have link.
Pat Garvey |
May 3 2009, 06:58 PM
While looking at the AA catalog to find fuel hoses, I found a statement that the recall back in the day replaced the fabric covered lines with rubber lines less affected by battery acid. My one-owner '70 (which was out of the country for much of the early 70's) has all fabric covered fuel lines and they look very old. Could it be that they were never replaced under recall? Will Porsche still honor the recall and replace my lines? I seem to remember reading something on the issue on this board but can't find it through the search feature. It's my understanding that the recall is still active (do they ever die?). So long as your 914 has nor been refitted, it SHOULD qualify. Now, I should quailfy this with the fact that many/most were retrofitted with cloth faced fuel lines. AA is incorrect here. Regardless, if the "campaign" hasn't been performed on your 914, they owe you one. My bet is it was done - many years ago, with similar fuel ines, which were fabric covered. Or.....maybe not. Check with your dealer (such as it may be). Pat |
Jasfsmith |
May 4 2009, 08:36 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
It's my understanding that the recall is still active (do they ever die?). So long as your 914 has nor been refitted, it SHOULD qualify. Now, I should quailfy this with the fact that many/most were retrofitted with cloth faced fuel lines. AA is incorrect here. Regardless, if the "campaign" hasn't been performed on your 914, they owe you one. My bet is it was done - many years ago, with similar fuel ines, which were fabric covered. Or.....maybe not. Check with your dealer (such as it may be). Pat All the updates I saw were smooth rubber faced, not cloth. |
Johny Blackstain |
May 4 2009, 04:49 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Original or not, the best solution is Tangerine Racings' stainless steel lines. Poof! Problems solved for life. My 74 has it's original clear vinyl tubes & I'm scared to death to touch them.
Pat Garvey |
May 4 2009, 06:48 PM
Original or not, the best solution is Tangerine Racings' stainless steel lines. Poof! Problems solved for life. My 74 has it's original clear vinyl tubes & I'm scared to death to touch them. No, we're talking about the high pressure rubber lines from the fuel pump to the fuel distributor, to the injectors. Not the plastic lines, which are not part of the recall. FWIW, my 72 still has its plastic lines too. Many times, I've pushed them out of the way, twisted them & tied them off, without a problem. I think the whole safety concern is nuts & a reason to sell parts. If they fail, go with Tangerine. Otherwise, leave them alone. Agree that the stainless tubes are better parts, but what do you use after they exit the pan? Pat |
Johny Blackstain |
May 5 2009, 08:43 AM
No, we're talking about the high pressure rubber lines from the fuel pump to the fuel distributor, to the injectors. Not the plastic lines, which are not part of the recall. FWIW, my 72 still has its plastic lines too. Many times, I've pushed them out of the way, twisted them & tied them off, without a problem. I think the whole safety concern is nuts & a reason to sell parts. If they fail, go with Tangerine. Otherwise, leave them alone. Agree that the stainless tubes are better parts, but what do you use after they exit the pan? Pat Ah, sorry, my mistake Pat. I'd replace the rubber/cloth lines w/ new ones, as per the recall. They are still very much available. As for the vinyl lines from the tank, I still don't trust them & intend on replacing mine in both cars w/ stainless. |
Lo-Fi Version | Time is now: 4th May 2024 - 08:40 PM |
