Urgent! need help 1.8 l-jet, please stop me befor i do somthing stupid.... |
jsayre914 |
May 7 2009, 12:10 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I got to baltimore barley, i lost all power and found that cylendr left front was not firing at all, pull the wire no change in rpm.
1) i checked for spark and the wire has spark shooting out at plug side 2) i checked the plug, it was bone dry. 3) i pulled the injector harness off and checkd that there was a pulse. 4) i figure this injector just quit.... I checked my stash of parts and i have a good injector from a 1.7 (yellow top) I was thinking to slap this in place of the baje 1.8 injector. The engine is a 1.8 l-jet. I dont want to damage the resistor pack or anything eles.... i just want to get the car home 60miles to pa. car runs pretty good on three cylenders. can i use the yellow injector and not f%^* up anything ???? please advise (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/chair.gif) |
Cap'n Krusty |
May 7 2009, 12:19 PM
No, you can't. The Cap'n
brant |
May 7 2009, 12:21 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the 1.7 (djet) and 1.8 (ljet) injectors work differently.
not interchangeable |
7275914911 |
May 7 2009, 12:23 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
I believe it is the difference in Flow Rates that make them unique??
Ken |
brant |
May 7 2009, 12:29 PM
the Djet injectors open and close for specific amounts of time
this is calibrated by the injection points in the lower distributor and thus changes with rpm I thought (could be wrong) that the Ljet injectors work differently aren't they similar to CIS injectors? I know you would not have injection points to open the injector on Ljet system. My guess is that if you install a 1.7injector, it never opens and NO FUEL at all flows though it... perhaps I'm wrong. another alternative could be that the ljet computer opens the 1.7 injector and it never closes? (tons and tons of fuel) the systems work differently I don't think I would try any mix and matching if you must drive it 60 miles, it would be better to pull the spark plug wire and drive it on a dry cyclinder than it would to put the wrong injector in brant |
davesprinkle |
May 7 2009, 01:00 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
the Djet injectors open and close for specific amounts of time this is calibrated by the injection points in the lower distributor and thus changes with rpm I thought (could be wrong) that the Ljet injectors work differently aren't they similar to CIS injectors? I know you would not have injection points to open the injector on Ljet system. My guess is that if you install a 1.7injector, it never opens and NO FUEL at all flows though it... perhaps I'm wrong. another alternative could be that the ljet computer opens the 1.7 injector and it never closes? (tons and tons of fuel) the systems work differently I don't think I would try any mix and matching if you must drive it 60 miles, it would be better to pull the spark plug wire and drive it on a dry cyclinder than it would to put the wrong injector in brant Ljet injectors are pulsed. They function like the Djet injectors, not like CIS. Flowrates are different, Ljet and Djet, so they can't be interchanged. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:12 PM |
