> Engine whining sound
craig3x
post May 8 2009, 09:25 PM
ok, My totally stock 1973 914 1.7FI is whining. It starts up fine and sounds normal. but as soon as you get the RPMs up over 1500rpm, something starts making a whining sound and it is a throttle sensitive sound. Almost like a gear drive sound, but not as extreme. Once the sound starts, it doesn't go away, even at idle. I have no idea what it could be. The car runs fine, buit has recently started burning oil and smoking a bit. Please offer any suggestions!!!
detoxcowboy
post May 8 2009, 09:37 PM
Region Association: Africa
QUOTE(craig3x @ May 8 2009, 08:25 PM) *
I had a funny whining sound simailar.. ATERNATOR BEARINGS.. Eventually I found out pretty fast and rude load whinnin screech.. took about 6 weeks of wondering what the funny little whinning sound was.. was'nt always there car ran good voltage too, ran great.. bearings were going..
ahdoman
post May 8 2009, 10:08 PM
It's phonetic...Ah-D-O-Man (Audioman)
Fan belt slipping?
craig3x
post May 9 2009, 07:56 AM
QUOTE(perrin1097 @ May 8 2009, 08:37 PM) *
That makes perfect sense actually because the sound first started right after I used my car to jump start a dead battery. I could tell it was loading up the generator pretty hard. Thanks!
So.Cal.914
post May 9 2009, 09:17 AM
"...And it has a front trunk too."
QUOTE(craig3x @ May 9 2009, 06:56 AM) *
Alternator.
First lets check the stuff that does not cost money. With the engine OFF, reach your hand inside the fan and see if you picked up something from the road. I have picked out pieces of plactic sheeting a few times. Make a heck of a noise.
IronHillRestorations
post May 9 2009, 12:39 PM
I. I. R. C.
I 2nd what Clay said. I've picked leaves and other noisy stuff out of the cooling housing and impeller.
post May 9 2009, 01:46 PM
Resident German
Vacuum leak ...
(IMG:style_emoticons/default/shades.gif) Andy
Drums66
post May 9 2009, 02:40 PM
914 Rudiments
this was your first mistake!!!!
I don't jump start any vehicle...........with a stock 914 electrical system
their too sensitive.......I think you toasted your Alternator....and whatever else??
914rat
post May 9 2009, 03:21 PM
Throw out bearings can make a whining noise.They could also be sensitive to higher revs when they are going bad.
- Lo-Fi Version Time is now: 6th July 2025 - 01:47 AM
