What Gallon capacity fuel cell r u running? |
GaroldShaffer |
May 13 2009, 09:29 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Moby, my old FP racecar has a ATL SP108 fuel cell that holds 8 gallons. Since it now has a 3.0L /6 instead of the FP 1.8 /4 in it I am thinking when I start road racing I will need a bigger fuel cell, no? The 8 gallons is plenty for AXing, butis it enough for road racing?
(IMG:style_emoticons/default/confused24.gif) |
Randal |
May 13 2009, 10:29 PM
Moby, my old FP racecar has a ATL SP108 fuel cell that holds 8 gallons. Since it now has a 3.0L /6 instead of the FP 1.8 /4 in it I am thinking when I start road racing I will need a bigger fuel cell, no? The 8 gallons is plenty for AXing, butis it enough for road racing? (IMG:style_emoticons/default/confused24.gif) The fuel cell is 12 (maybe) 15 gallons in the Beast; 5 gallons in "222." Running a 20 minute session in the Beast uses about about 5 or 6 gallons. |
brant |
May 13 2009, 10:35 PM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
rule of thumb for a teener race car
4cylinder = 10gallon 6 = 12gallon you could probably get away with a 10 on a 6 but why imagine your going to do an enduro some day... why not go for 12 I run 15 in my 2.0/6 I often go out with 5gallons in it and come back with 1/2 but why not have the ability to do an enduro they are WAY... way ... way more fun than a spring w2w we ran an enduro on a 2.1 mile course with 86 cars probably the best race I have ever particpated in. it was pass and be passed about 2 times every corner for 2 hours. brant |
Joe Ricard |
May 14 2009, 05:26 AM
Figure 7 MPG on the track. go from there what do you need to accomplish.
I am putting a 5 gallon tank in my car. enough for 20 minute race. and run a gallon in it for autocross. |
Randal |
May 14 2009, 07:58 AM
Figure 7 MPG on the track. go from there what do you need to accomplish. I am putting a 5 gallon tank in my car. enough for 20 minute race. and run a gallon in it for autocross. (IMG:style_emoticons/default/agree.gif) But don't forget, when you motor starts doing funny things, to check the gas first! |
GaroldShaffer |
May 14 2009, 08:59 AM
Figure 7 MPG on the track. go from there what do you need to accomplish. I am putting a 5 gallon tank in my car. enough for 20 minute race. and run a gallon in it for autocross. (IMG:style_emoticons/default/agree.gif) But don't forget, when you motor starts doing funny things, to check the gas first! (IMG:style_emoticons/default/rolleyes.gif) Yep learned that the hard way with my first AX this year. I thought I put gas in the car a few days before my 5th run of teh day car started cutting out on hard right turns, on 6th run fuel pump was making a REAL bad sound. I shut things down and yep, out of gas (IMG:style_emoticons/default/slap.gif) Fuel is now TOP on my pre-AX/Track day/whatever list. |
Joe Ricard |
May 14 2009, 01:10 PM
Living on the edge requires more work and infiniatley more things to Fuk up.
Randal |
May 14 2009, 02:37 PM
Figure 7 MPG on the track. go from there what do you need to accomplish. I am putting a 5 gallon tank in my car. enough for 20 minute race. and run a gallon in it for autocross. (IMG:style_emoticons/default/agree.gif) But don't forget, when you motor starts doing funny things, to check the gas first! (IMG:style_emoticons/default/rolleyes.gif) Yep learned that the hard way with my first AX this year. I thought I put gas in the car a few days before my 5th run of teh day car started cutting out on hard right turns, on 6th run fuel pump was making a REAL bad sound. I shut things down and yep, out of gas (IMG:style_emoticons/default/slap.gif) Fuel is now TOP on my pre-AX/Track day/whatever list. Yup, as soon as my car is off the trailer that's the first thing I do. Then I do it again right before lunch. I'd rather have a couple of extra gallons in there as opposed to having to throw out a run. |
pcar916 |
May 14 2009, 03:12 PM
Mine's a 15 gallon Fuel Safe cell with an aluminum case and a 1 gallon surge tank.
With the surge tank I don't have to fill it up for short events since the fuel-injection return line keeps it filled constantly. Good Luck! ~Ron |
Randal |
May 14 2009, 03:23 PM
Mine's a 15 gallon Fuel Safe cell with an aluminum case and a 1 gallon surge tank. With the surge tank I don't have to fill it up for short events since the fuel-injection return line keeps it filled constantly. Good Luck! ~Ron No question, don't forget one of these: |
HAM Inc |
May 14 2009, 04:03 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Another thing to keep in mind is that if you start a race with the cell packed with fuel and have a front impact that gets to the cell, there's a good chance you'll burst it. I like having more cell than I need for the length of my races. That extra air space gives the cell more crushability. Doesn't matter how good the cell is, fuel still won't compress!
Randal |
May 14 2009, 05:40 PM
Another thing to keep in mind is that if you start a race with the cell packed with fuel and have a front impact that gets to the cell, there's a good chance you'll burst it. I like having more cell than I need for the length of my races. That extra air space gives the cell more crushability. Doesn't matter how good the cell is, fuel still won't compress! Well said, by a man that has probably seen more fuel cells get chrushed than any of us, given where he learned to race. Good advice Len. Thanks! (IMG:style_emoticons/default/smilie_pokal.gif) |
brant |
May 14 2009, 11:19 PM
we often return with 1/2 gallon or less.
sometimes less than 1/8th some type of surge tank or reservoir is mandatory. (especially for F.I. !) on the 2.0 at high altitude (small jets) we run about 15 gallons an hour that is a safe baseline and you will probably not surpass that if you are in the 200hp area... Attached thumbnail(s) Attached image(s) |
HAM Inc |
May 15 2009, 07:16 AM
QUOTE Well said, by a man that has probably seen more fuel cells get chrushed than any of us, given where he learned to race. Thanks Randall! And yes, unfortunately I have seen my share of ruptured cells first hand. The start of a race is the most dangerous time in a race, in part because that is when cars have the most fuel on board. |
jt914-6 |
May 16 2009, 05:33 AM
Driving & working on teeners 41 years Group: Members Posts: 1,785 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
12 gal. for use with 3.0 RS spec. engine and street/track use.
MikeSpraggi |
Jun 1 2009, 07:04 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
I have a 15 gal. ATL I'm installing in my DE/Track car. This thread is good reading with some good advice.
puff adder |
Jun 2 2009, 08:51 AM
Member Group: Members Posts: 77 Joined: 9-December 08 From: northern california Member No.: 9,827 Region Association: None |
Here's the cell on my car. Another configuration, probably 8 gallons. Fits into the stock modified tank.
Heeltoe914 |
Jun 30 2009, 11:55 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
[quote name='brant' date='May 14 2009, 10:19 PM' post='1169636']
we often return with 1/2 gallon or less. sometimes less than 1/8th some type of surge tank or reservoir is mandatory. (especially for F.I. !) Brant I like the little tank you have mounted in the car I run a 6 gal tank and get about 20 mins. If running with the extra accumulator I can get 2 more laps and every drop of fuel I would be happy. Where did you buy that tank? And can you show me the routing and the way it works. |
sww914 |
Jul 1 2009, 12:41 AM
I have a 12 gallon cell. Hotrod 2056 with Weber 44's. I fill it almost all the way up, say to 10 gallons and I get 3 run sessions before it starts getting low. I can't quite get 4 20 minute sessions unless I fill it up all the way, but it's like Ham said.
brant |
Jul 3 2009, 12:30 PM
[quote name='Heeltoe914' date='Jun 30 2009, 11:55 PM' post='1187285']
[quote name='brant' date='May 14 2009, 10:19 PM' post='1169636'] we often return with 1/2 gallon or less. sometimes less than 1/8th some type of surge tank or reservoir is mandatory. (especially for F.I. !) Brant I like the little tank you have mounted in the car I run a 6 gal tank and get about 20 mins. If running with the extra accumulator I can get 2 more laps and every drop of fuel I would be happy. Where did you buy that tank? And can you show me the routing and the way it works. [/quote] its really designed as a surge tank, to keep fuel from splashing from side to side and evading the fuel pick up. Its a moroso oil accumulator with new AN fittings TIG welded onto it to convert it over for use with fuel. the routing is that one fuel pump picks up from the cell, runs through a filter, and then into the surge tank. Out of the bottom of the surge tank, a 2nd fuel pump runs back to the carbs, or f.i (these systems are absolutely necessary for racing ITB's or F.I. systems that need to maintain constant fuel supply) After feeding the induction, the fuel is routed back in a circulatory system to return to the tank. Additionally the surge tank has an overflow that also returns to the tank Cool recirculatory fuel is your friend! brant |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:21 AM |
