car won't start, let the frustration begin. now rear wheels stuck |
nycchef |
May 18 2009, 12:23 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
74 2.0 dual weber carbs, fuel pump running, fuel in the lines, pertronix ignition, don't seem to be getting a spsark. disconected the coil wire and held it close , no spark, disconected a spark plug wire at the dizzy, no spark, disconected the plug wire at the plug, held it near the tin, nothing. getiing 12v at the coil. what am i missing?
iamchappy |
May 18 2009, 01:01 PM
Chef, could be just a bad or broken coil ignition cable. If the distributor has been out or replaced it maybe 180 out.
bobhasissues |
May 18 2009, 01:07 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
74 2.0 dual weber carbs, fuel pump running, fuel in the lines, pertronix ignition, don't seem to be getting a spsark. disconected the coil wire and held it close , no spark, disconected a spark plug wire at the dizzy, no spark, disconected the plug wire at the plug, held it near the tin, nothing. getiing 12v at the coil. what am i missing? Did you do any work on the car prior to this? Or, was it running and now it isn't. Could be a lot of things if you just worked on it. Probably the Pertronix shutter unit if it just stopped. Look at their site for troubleshooting the unit. |
tradisrad |
May 18 2009, 01:30 PM
if the pertronix is hooked up backwards it will fail.
did you do some work and forget to reinstall your rotor? |
nycchef |
May 18 2009, 03:25 PM
if the pertronix is hooked up backwards it will fail. did you do some work and forget to reinstall your rotor? update... tried a different coil same sh..., went back to original and retested voltage came in @10.3. volts |
iamchappy |
May 18 2009, 03:59 PM
Put #1 cylinder at tdc. Pull distributor replace distributor so the rotor is pointing just short of being straight towards the left side of the inspection hole - actually more like the bend in the black flapper rod. Make sure the cap has the plug wires in the correct firing order and the rotor is pointing to fire #1.
Retime with strobe light after it starts. I just went through this with Paul (lotus65's) car. He has points so it was easier for me because i was able to use my static timing light for a starting point. |
type11969 |
May 18 2009, 04:24 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
Even if the distributor is 180 out he should be getting spark when holding the ign wires close to ground.
Speaking of ground, is your tranny ground hooked up? |
nycchef |
May 18 2009, 04:26 PM
Put #1 cylinder at tdc. Pull distributor replace distributor so the rotor is pointing just short of being straight towards the left side of the inspection hole - actually more like the bend in the black flapper rod. Make sure the cap has the plug wires in the correct firing order and the rotor is pointing to fire #1. Retime with strobe light after it starts. I just went through this with Paul (lotus65's) car. He has points so it was easier for me because i was able to use my static timing light for a starting point. thanks i,ll try that. by the inspection hole do you mean the round plastic plug used for timing? also i just tried putting a screwdriver in the coil wire a 1/4 inch off the tin and turned the engine, no spark while it was cranking but a single spark when i put the key back into the run position did it 6 times to make sure i,m not nuts |
Jeffs9146 |
May 18 2009, 06:10 PM
Sounds like Ign switch is miswired or the ign wire is shorted to ground when the started is engaged.
As said above, What work have you done recently?? |
swl |
May 18 2009, 07:18 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Rich says he has no spark - not a general no start issue. The 180 thing would not stop the spark. Just it would spark at the wrong time. He has 10v at the coil - that's low but not low enough to stop a spark at all. You are going to have to look at that at some point Rich. There was some thought in another thread about the miswired switch giving 12v only in the on position (not in the start). Measure again while trying to start. If you have 12v to the coil during start then the problem has to be somewhere in the dizzy - no switch to ground.
Edit: no spark while it was cranking but a single spark when i put the key back into the run position did it 6 times to make sure i,m not nuts That really sounds like it may be the miswired switch. You get the spark when the key goes back to 'on' and the motor hasn't quite stopped. Maybe? |
nycchef |
May 18 2009, 07:24 PM
Sounds like Ign switch is miswired or the ign wire is shorted to ground when the started is engaged. As said above, What work have you done recently?? this is a 74 engine that was running that i put in my car to replace my 1.7. d jet. i put in all new seals and a new clutch. and put it in. i just now tried chappy's idea of bringing the #1 piston to tdc and have discovered that my rear wheels will only move a 1/4 of a turn , then there is a thud, this happens in all gears. i can hear the clutch shifting although it is a little spongy. it doesn't seem to be the brake, the emergency brake holds fine. (IMG:style_emoticons/default/biggrin.gif) |
nycchef |
May 18 2009, 07:43 PM
[/quote] that;s it exactly. how do i rewire the switch? could it be that this is still the harness from my 1.7 d-jet? |
iamchappy |
May 18 2009, 07:47 PM
I wish i was there to help you.......
There is nothing like seeing it for yourself.... |
nycchef |
May 18 2009, 07:48 PM
I wish i was there to help you....... There is nothing like seeing it for yourself.... i wish i was there, i've seen too much (IMG:style_emoticons/default/headbang.gif) |
iamchappy |
May 18 2009, 07:52 PM
Go stirfry something, have a beer or two and watch the Yanks sweep the Twins...
swl |
May 18 2009, 08:20 PM
nycchef |
May 18 2009, 08:24 PM
that;s it exactly. how do i rewire the switch? could it be that this is still the harness from my 1.7 d-jet? First things first. Measure the voltage at the coil with the key in the start position . at first 6v then it jumped to 10.3v |
May 18 2009, 08:39 PM
got a place to crash?
Safe place to park? I will come down if you want. Rich |
nycchef |
May 18 2009, 10:01 PM
iamchappy |
May 19 2009, 07:58 PM
Chefie, any new news, i was tempted to give you a call while the server was down.
Lo-Fi Version | Time is now: 12th May 2024 - 04:22 PM |
