Buzzer for low oil pressure. |
ahdoman |
May 20 2009, 07:35 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Any of you /6 guys ever add a buzzer to your low oil pressure light? If so, how?
charliew |
May 20 2009, 07:52 PM
Some senders also have a extra terminal for a light or buzzer.
May 20 2009, 07:54 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You could use the current to the light as a trigger for a relay which in turn feeds a buzzer.
The problem is, at least on my car, the light is on when you turn the key and goes out when the engine starts. That means, any buzzer off the light circuit would buzz with just the ignition key on. That would get annoying pretty quick. (IMG:style_emoticons/default/idea.gif) Andy |
jt914-6 |
May 20 2009, 08:07 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I think Andy is right. My oil pressure light comes on at idle. I'm using a decent size amber LED light on my dash for the "idiot light". It will get your attention when a buzzer wouldn't @ 6800 rpm and the top off!!!!!
ahdoman |
May 20 2009, 09:13 PM
I'm OK with it buzzing along when the light is lit. I just don't want to miss the light if I loose oil pressure while driving. It would be just a safe guard.
Wes V |
May 20 2009, 09:26 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
Try the "the12volt.com" website. They may already have a circuit drawn up.
Wes |
lotus_65 |
May 20 2009, 09:27 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
why couldn't you just switch the buzzer independently?
(IMG:style_emoticons/default/confused24.gif) once the car's on the road, throw the rocker and enable the audio... that sounds like an easy circuit to me. (no pun intended (IMG:style_emoticons/default/happy11.gif) ) |
detoxcowboy |
May 20 2009, 09:35 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Attach a jump wire from the light wire to your horn button wire when the light comes on your horn will ground and you will know the light is on from the horn.. hopefully you never get the low idle light flicker finger..
jmill |
May 20 2009, 09:37 PM
Fairly easy addition off of the existing pressure switch. I'm assuming the pressure switch closes to ground at low pressure. The only thing you would have to do is be sure that the power supply to the buzzer is switched with the key. You can add another relay off the ignition and have the buzzer supplied directly from the battery or you can use an existing switched supply.
bdstone914 |
May 20 2009, 09:43 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Any of you /6 guys ever add a buzzer to your low oil pressure light? If so, how? Steve, I have the senders with two poles if you are running a gauge and want the light function. If you have the stock fuel/brake light gauge you could splice into that light and a buzzer. It is hard to miss that light. Bruce |
drive-ability |
May 20 2009, 10:50 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Use a Vacuum switch, that will work independently and control ether a pos or a neg. I'm looking for one right now via eBay to trigger at high manifold vacuum to simulate braking for my brake lights. I worked for GM and in the late 80s and early 90s the egr valve in Buick's 6 cylinders used a vacuum switch to inform the engine computer the egr is getting vacuum. I've used them to trigger a relay. Its a small package when you remove the switch. |
orange914 |
May 22 2009, 12:34 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Fairly easy addition off of the existing pressure switch. I'm assuming the pressure switch closes to ground at low pressure. The only thing you would have to do is be sure that the power supply to the buzzer is switched with the key. You can add another relay off the ignition and have the buzzer supplied directly from the battery or you can use an existing switched supply. (IMG:style_emoticons/default/agree.gif) |
davesprinkle |
May 22 2009, 09:25 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Use a Vacuum switch, that will work independently and control ether a pos or a neg. I'm looking for one right now via eBay to trigger at high manifold vacuum to simulate braking for my brake lights. This seems like a misguided idea. They're BRAKE lights, not VACUUM lights. Why not just use the brake switch? Failing that, install a brake system pressure switch. |
May 22 2009, 10:02 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I have heard discussions from racers on hooking up a horn that sounds when only one of the oil or generator lights are on, but not both. You would likely get a short blast on start-up, as the one or the other light goes out first, but then you'd only get a warning if the oil pressure dropped or the fan belt went.
--DD |
drive-ability |
May 22 2009, 11:13 AM
Use a Vacuum switch, that will work independently and control ether a pos or a neg. I'm looking for one right now via eBay to trigger at high manifold vacuum to simulate braking for my brake lights. This seems like a misguided idea. They're BRAKE lights, not VACUUM lights. Why not just use the brake switch? Failing that, install a brake system pressure switch. The vacuum system would be an additional system to the factory brake system. I find with a V-8 the engine is an effective braking system but the folks behind me are slow to pick up on this without a light coming on. On heavy deceleration what ever you peek vacuum production is a light would work well along with the factory brake switch.. IMO (IMG:style_emoticons/default/smile.gif) |
yeahmag |
May 22 2009, 11:21 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
There are some pretty loud, and low amp piezo electric buzzers I've been looking at for the same purpose. I was planning on piggy backing it to the oil light...
J P Stein |
May 22 2009, 11:24 AM
The low pressure at hot idle is an easy fix with the cam oil line restrictor. I now hold 2 bar at idle. There are differing opinions as to sufficient cam oiling with the restrictors installed....do your research and make your own decision.
Elliot Cannon |
May 22 2009, 11:31 AM
You want to hear an annoying buzzer everytime you turn on the key? Take out the clock on your dash and install a great big oil pressure light like the racers use. Maybe hook the oil pressure switch to the windshield washer pump? Or to a computer chip with a sexy voice that says "Darling, your oil pressure is low". (I would recommend a womans voice). Maybe a chip with Slits saying, "Hey, asshole, your oil pressure is low". I'm also thinking a low power tazer under you seat. OK maybe the big oil pressure light would ruin the look of your new dash but I'm just trying to help. (IMG:style_emoticons/default/lol-2.gif)
Cheers, Elliot |
JoeSharp |
May 22 2009, 12:31 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Murphy Switchage makes a oil pressurs gage that turns your engine off if the pressure gets to low.
yeahmag |
May 22 2009, 12:33 PM
I've been told those are dangerous and can cause a spin, but what do I know...
Lo-Fi Version | Time is now: 11th May 2024 - 09:49 AM |
