My Six Conversion - School Bus Yellow, 1st time conversion project for me |
MikeSpraggi |
May 20 2009, 11:59 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
So I find this '70 914 on Craigslist for $700. Says it's only a shell. Has flares and 5 bolt 911 pattern on all 4 wheels. I call, make an appointment for 2 days later. Car looks like it has good bones. I asked "what happened to the engine and trans?" The guy says, "Oh, it runs". So I buy it. It's going to be my DE/track car. That was THREE years ago. So to get the original six off the track, I started to "put" the project together.
I had been collecting parts for a six conversion for about 10 years or so. I have just about everything I need, but, this is a LOT of work and a LOT of $$$ if you add it all up. Wife keeps asking, when is it going to be finished ............. (IMG:style_emoticons/default/lol-2.gif) Here are some pics. As seen on Craigslist in Philly in Feb of 2006. FG bumpers did not come with the car, but a 1.7L engine did. 2 years later after I bought the FG hood and trunk and replica Fuchs |
MikeSpraggi |
May 21 2009, 12:11 AM
I haven't done anything like this, but have been reading the 914 Forums for quite some time.
Starting down the road ..... This was some of the worst rust .. front trunk rubber seal area Rear trunk stripped and primed ..... Fitting the can for the fuel cell |
MikeSpraggi |
May 21 2009, 12:27 AM
Setting up fitment for the air dam I bought more than 10 years ago for my 1st 914. Need to fabricate the mounting brackets.
Purschased Koni yellows all the way around along with 16X7 front and 16X8 Phone dials .. A little more progress on the interior ... Had to frabricate brackets for the Mazda RX-7 front mounted oil cooler .... Pattern for the air dam mounting brackets .. probably will make the real ones next week. Checking fitment of air dam and oil cooler ... need to cut out the brake cooling ducts. Spent a LOT of time redoing the air dam. Not perfect, but hey, it's a track car! |
brant |
May 21 2009, 12:30 AM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
have you considered opening up the fuel firewall and moving the cell rearward?....
its really much better for weight distribution with no loss of rigidity. (not as sealed of a trunk floor though... but its not going to be a DD is it?) |
MikeSpraggi |
May 21 2009, 12:37 AM
Picked up side shifter in N.J. about 2 months ago. Need to have Dr. Evil go over it.
Power is a (ahem) 2.2L six .... maybe a little north of stock (IMG:style_emoticons/default/shades.gif) . As I said, I have never done anything like this or close to this. I knew these projects were "big" in scope and $$$$. I also knew it's good when you can purchase someone else's unfinished or unwanted project. But no, I had to experieince the whole thing myself!! (IMG:style_emoticons/default/headbang.gif) ............ Still no regrets. Want to get it on the track sometime this summer. Couldn't do it without this forum. THANKS!! |
MikeSpraggi |
May 21 2009, 12:43 AM
have you considered opening up the fuel firewall and moving the cell rearward?.... its really much better for weight distribution with no loss of rigidity. (not as sealed of a trunk floor though... but its not going to be a DD is it?) I did consider that, however a 16 qt Peterson oil tank will be located where the stock gas tank is currently sitting. I've seen a number of cars configured as you mentioned, makes a lot of sense. |
JRust |
May 21 2009, 12:45 AM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Nicely done man! Good progress & looks to be a great start to your future track days (IMG:style_emoticons/default/aktion035.gif)
FourBlades |
May 21 2009, 09:24 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
That is a great project and a nice looking engine. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) Keep posting the pictures, you can never have too many resto and build pictures. That will be a fantastic track car when you are done. John |
ahdoman |
May 21 2009, 09:34 AM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Before it's too late... I've been told (by guys who know this stuff) that you want a 1:2 venting ratio on the oil cooler. You're setup with putting the cooler in front of the vent holes in the chassis may severly limit it's cooling abilities not to mention you run a good chance of damaging it on any unwanted off track excursions. Most guys put it on the trunk side of those holes. There's a guy on Ebay selling the original GT type glass vents as well to make the job a little easier.
type47 |
May 21 2009, 01:29 PM
Nice! Good to finally see some of your project even though we're close in location. I'd like to talk to you about your body prepping, ie, the primer, primer application method, etc. I have a project that needs removal of old primer and re-primer application.
MikeSpraggi |
May 15 2010, 08:51 PM
Been doing body work and other odd and ends to prep the my track car for paint, suspension and engine installation. Just got the car back from the paint shop today. This is a budget job, but I'm really happy with it (for a track car. I bought the paint, did much of the body work and took it all to Maaco and had them shoot the car; exterior, interior and trunks! They did a decent job with what they had to work with.
Hauled the car up to GT Performance in Edgewood, Md. for the suspension and engine install. I can't believe this is really happening. It's been a dream for more than 20 years but life always came first (wife, kids, house, school. etc.). I still have all of the aforementioned thankfully (IMG:style_emoticons/default/beerchug.gif) . Anyways, more $$$ to complete. Smart people who want to track a car will buy someone else's project, I knew that ... I'm just not smart (IMG:style_emoticons/default/lol-2.gif) . On its' way to the paint shop. After paint shop and at GT Performance. |
EdwardBlume |
May 15 2010, 09:47 PM
(IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) Nice progress... I dig orange race cars! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
veltror |
May 16 2010, 02:23 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Exactly what colour has it been painted?
carr914 |
May 16 2010, 05:26 PM
Racer from Birth Group: Members Posts: 118,258 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
If it is a Track Car, get rid of those Replica Fuchs & buy some real wheels.
T.C. Sorry, I saw that you bought some Cookie Cutters, but I thought that Cookies were only available in 6" & 7"s, not 8"s |
MikeSpraggi |
Oct 25 2010, 12:28 AM
I thought this project was going to be ready by the end of this past summer. Guess again! Sure, I was a little optimistic and really wanting to get the green /6 off of the track 'cause it's really taking a beating. Last track event at VIR I snapped the passenger side U-tab for the anti-sway bar drop link. Fortunately, got it welded back on at the track by a Grand-Am team whose shop is located at the track. Anyways, a couple of more pics of the track car progress.
Here's the car on the lift at GT Performance. The 911 struts and anti-sway bar have been installed. Here is the Autopower weld-in roll cage installed. The windshield has since been removed. Gas tank cavity clear out for anti-sway bar installation and soon to be installed Peterson 16 quart oil tank. I have since decided on moving the Mazda RX-7 oil cooler inside the trunk instead of outside ... yea I know .. why the outside (IMG:style_emoticons/default/confused24.gif). Anyways, my job gave me an Amazon gift certificate that was just enough to buy a new ATL 12 gal fuel cell, so now there's enough room for the cooler and the cell. Hope 12 gals is enough for 30-40 minute runs! |
MikeSpraggi |
Oct 25 2010, 12:47 AM
The 914 GT stiffening kit has been welded in.
The rear shocks will be replaced with these Konis and the Rebel Racing adjustable perches accompanied by 225 lb Eibach springs. The newly rebuilt SC front calipers are being replaced with 951 front calipers. These may cause an issue initially for the vintage racing group I would like to eventually run with, but another teener has been allowed to run with them (IMG:style_emoticons/default/sunglasses.gif) . |
MikeSpraggi |
Oct 25 2010, 01:04 AM
Getting ready for the engine install. The Patrick engine mount has been welded in.
Also, rear pickup point reinforcing kit from Chris at Tangerine Racing was installed along with the Heim rods. One more of the cage ..... That's it for now. Earlier I may have stated that I had found some 7 and 8 inch cookie cutters for the track wheels ... that should have read 7 and 8 inch phone dials. The replica Fuchs are just to move the car around, phones are for the track right now. I have mounted Dunlop Star Z1s on the rims. We'll see how that works out. That's all for now, but more to come. |
kenshapiro2002 |
Oct 25 2010, 05:12 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Pretty sure I remember seeing that puppy up at Gennady's this summer when pickle got her 4 wheel alignment.
MikeSpraggi |
Oct 25 2010, 11:13 AM
Pretty sure I remember seeing that puppy up at Gennady's this summer when pickle got her 4 wheel alignment. Yea, it's been up there for awhile. Hope to have it completed by December. It'll look pretty rough until I get the bumpers on and have the paint a little "refreshened" from all the work being done to it. In it's previous life, it was definitely hit in the rear passenger side corner and very mildly in the front, below the hood. The bumpers will cover those areas up. Other than that only very minor rust issues. It will be a dedicated track car and definitely not a garage queen. |
bcheney |
Oct 25 2010, 12:36 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Nice looking project. I am doing a narrow body conversion with a 2.2 rebuilt motor with e spec cams, larger ports, 3.0 liter oil pump etc etc. Keep the faith...that is going to be one damn nice car when you're done!
Lo-Fi Version | Time is now: 29th April 2024 - 07:05 AM |
