Subaru WRX 23 914 Progress Thread in AZ (252 HP at the wheels!)), The results are in! 252 HP and 262 torque!! (read last pag |
budman5201 |
May 21 2009, 07:51 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
Here is my Subaru Turbo exhaust. I think I finally got TIG welding down pat. Have to be comfortable when welding.....About another month or so and this baby is running....19 LBS boost!
budman5201 |
May 21 2009, 07:59 PM
Here is my Subaru Turbo exhaust. I think I finally got TIG welding down pat. Have to be comfortable when welding.....About another month or so and this baby is running.... SO guys, I have a renegade subaru engine cradle and I promised that i wouldnt show it, but how do I show my work off on this site without doing that? Basically its their engine mount and everthing else is mine.....Its right around all my work! (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Here is my Heat Exchanger for my Air/water intercooler. I used a standard air/air intercooler (about half the price for a huge one) and i am chopping the sides welding them up, putting 1/2 flared fitting on each side, then i will have a 26x6x2.5 aluminum heat exchanger right out front....Front not near done yet Attached image(s) |
raw1298 |
May 21 2009, 08:02 PM
Senior Member Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California |
You could photo shop it out or paint it camo so we can't see it! (IMG:style_emoticons/default/lol-2.gif)
jd74914 |
May 22 2009, 06:32 AM
Or we could just not look. :wink:
charliew |
May 22 2009, 08:45 AM
You know what? that is so stupid, how many ways can you bend tubing, hold a suby motor and make it bolt in. Besides I really think most suby transplants from here on out will be using suby trannys for their reliability and better gearing. Try buying a lsd for 400.00 for a 901. You can get high strength shafts, dog box or syncros or a mixture. Even in stock configuration, if it were to equal the best built 901 it still would be a way newer design with a good aftermarket support. Now if subaru would only make a sequential tranny.
A air to air ic has a different internal core to flow air as unrestricted as possible (bigger tubes) where a water radiator needs to slow the water down to transfer the heat sufficently before it goes to the heat exchanger. I also think you will have too much airflow restriction in front of your radiator. Your tigging is looking good but you might want to add a extra piece of tubing to the flange to let the wastegate flow better. It looks like you lowered your turbo a lot, will it drain to the pan ok? |
budman5201 |
May 24 2009, 07:02 PM
Creative Photo taking. Nope TURBO still way up high, check out the photo of the turbo drain still way above like stock....
The air/air intercooler will have 1/2 inch lines so water will slow way down in the cooler itself since it was designed to be 2 inch air flowing through it...... As for position i debated putting it right just below the lower hortizontal sheet metal and cutting my LOW valance to fit around it since its low anyways, that way the radiator would have unrestricted flow, and the heat exchanger flow would go underneath the car.....it would just look so much better cosmetically if i could hide in just before the radiator. I did enlarge my hole to max height and width. Basically its 32 inches across by 12 inches high....Thats huge!! Attached image(s) |
budman5201 |
May 24 2009, 07:03 PM
another
budman5201 |
more
budman5201 |
May 24 2009, 07:04 PM
Renegade Makes a superior Product....Love that i didnt have to fab that up. !!
budman5201 |
May 24 2009, 07:19 PM
okay heres some pics of the air coming in up front, obviously not finished in any way...but hole width /height is staying.
budman5201 |
another
computers4kids |
May 24 2009, 07:30 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
SO guys, I have a renegade subaru engine cradle and I promised that i wouldnt show it Your kidding, right. By the way, nice work. (IMG:style_emoticons/default/smash.gif) |
DBCooper |
May 25 2009, 01:01 AM
No joke. Everybody who wants to look underneath a Rennegade car has to sign a non-disclosure agreement, so at car shows there are little lines that form, people doing the paperwork... (IMG:style_emoticons/default/laugh.gif)
BIGKAT_83 |
May 25 2009, 09:13 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
That can't be true I found these online.
orcadigital |
May 25 2009, 11:00 AM
Member Group: Members Posts: 59 Joined: 1-November 05 From: Elizabeth, CO Member No.: 5,043 |
As i am not very well versed on Turbos, i have a question...
Putting the intercooler on the front of a mid engine car seems like you would have incredibly long pipe runs... and most intercooler pipes i have seen attempt to have less bends and run shorter distances... The 914 turbos i have seen seem to mount the intercooler either in the engine bay on top of the engine, or in the rear trunk with ducting pulling air down to it. Just curious... |
plymouth37 |
May 25 2009, 11:09 AM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
No joke. Everybody who wants to look underneath a Rennegade car has to sign a non-disclosure agreement, so at car shows there are little lines that form, people doing the paperwork... (IMG:style_emoticons/default/laugh.gif) Just wait until I get to the mechanical part of my build, I designed the damn thing so I have no problem plastering photos of it all over my build thread... Your project is really coming together Budman, I have played around with the idea of an A/W intercooler and will be interested to see how yours turns out. |
budman5201 |
May 25 2009, 04:43 PM
As i am not very well versed on Turbos, i have a question... Putting the intercooler on the front of a mid engine car seems like you would have incredibly long pipe runs... and most intercooler pipes i have seen attempt to have less bends and run shorter distances... The 914 turbos i have seen seem to mount the intercooler either in the engine bay on top of the engine, or in the rear trunk with ducting pulling air down to it. Just curious... My intercooler run is going to be exactly 1 foot from the turbo into the Water/Air Intercooler and 1.5 back to the intake from the intercooler. The intercooler up front is and air/air that is going to be modified with 1/2 inch tubing in and out with a water pump pushing the water to/from the engine bay just like the renegade radiator, but i keep it serparate because the heat exchanger will be closer to ambient temperature unlike the engine which is 195 or 205 with the A/C on full blast. Basically its just a heat exchanger for the water/air intercooler in the engine bay. Water/air intercoolers have greater heat exchange properties than air/air ones, and especially with my gigantic heat exchanger up front. Ex. The new mustang has a heat exchanger 24x7 i think and its only an inch wide for its supercharger. Mine is 26x7x2.5 inches and aluminum also. SO plenty for this lower horsepower engine. Give me another few weeks and i should have the water intercooler plumbing in. |
pavpav12 |
May 25 2009, 05:32 PM
Newbie Group: Members Posts: 27 Joined: 20-April 07 From: mountaintop, pa Member No.: 7,680 Region Association: North East States |
looking good
strawman |
May 25 2009, 11:08 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Your project is really coming along. Great job!
I know what you mean about secrecy and Renegade. I visited his shop in Vegas a couple of months ago and was amazed at some of the projects in his shop, but he holds his cards pretty close to his vest. He is also pretty proud of his work and insistent that he has the optimal solution, basically poo-pooing some of my ideas. But I really enjoyed the tour. Did you consider reversing your intake manifold? See http://www.914world.com/bbs2/index.php?sho...83031&st=60 for details on what I'm doing for my Suby-powered 914... Geoff |
charliew |
May 25 2009, 11:53 PM
First time I've seen the rh engine mount but I had imagined a lot from other glimpses on other threads. It looks like the motor and tranny are tilted up and forward in the front to give the stock pan more ground clearance. If that is the case then the tranny is no longer level it seems. I have tried unlevel trannys in the past and it didn't work very well long term. Usually the front bearing gets too dry and if you don't lower the lube level it will usually leak in the rear. Course it's not a 901 so maybe there is no seals at the very rear to leak, just the speedo.
Bigkat you are soooo bad |
Lo-Fi Version | Time is now: 14th May 2024 - 01:57 AM |
