alternator belt |
alternator belt |
jea69 |
May 22 2009, 04:05 PM
doing unspeakable things to iron Group: Members Posts: 51 Joined: 13-March 08 From: norway Member No.: 8,811 Region Association: Scandinavia |
hello i have a question ,my car is twisting and throwing the alt belt, is there a way
to align the alternator without dropping the motor? i have a 1970 1,7 . (IMG:style_emoticons/default/confused24.gif) mid engine blessings (IMG:style_emoticons/default/barf.gif) |
Cap'n Krusty |
May 22 2009, 06:05 PM
What brand/size belt are you using? Gotta be 10x965, and it should be a European belt. Beyond that, you need to make sure the alternator body isn't worn at the mounting holes, and that both brackets are unworn and unbroken. Replacement of either probably requires removal of the alternator. The Cap'n
rjames |
May 22 2009, 06:37 PM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
What brand/size belt are you using? Gotta be 10x965, and it should be a European belt. Beyond that, you need to make sure the alternator body isn't worn at the mounting holes, and that both brackets are unworn and unbroken. Replacement of either probably requires removal of the alternator. The Cap'n Sorry for the hijack, but how often does the belt need replacing on average? |
Cap'n Krusty |
May 22 2009, 06:40 PM
What brand/size belt are you using? Gotta be 10x965, and it should be a European belt. Beyond that, you need to make sure the alternator body isn't worn at the mounting holes, and that both brackets are unworn and unbroken. Replacement of either probably requires removal of the alternator. The Cap'n Sorry for the hijack, but I was sold a Bryco belt, 9.5x965. Will that not work well? I didn't know anyone still made 9.5s. The size is what came on the car, but the 10mm belts seem to fit and work better. Bryco belts are Japanese. The Cap'n |
jea69 |
May 24 2009, 01:36 PM
hello again, been under the car and i found that the alt bracket vas bendt ,so i
straightened it , but it stil twists the belt , it is the correct belt by the way, there is a little freeplay in the alt mounting hole , is it suposed to be a tight fit? |
jea69 |
May 27 2009, 12:45 PM
problem solved , po has put the alt pully backside out ,was able to remove the nut
and flip the pully around without remowing the alt (IMG:style_emoticons/default/piratenanner.gif) heres what i did checing alignment: take a round steel bar 6mm (1/2") 35 cm long (check its straight), between the alt and fan pully there is a long stud , let the rod rest on the stud and push it into the fan pully v groove , put the other end on top of the alt v groove , check with mirror to see if it crosses over the alt pully, eaven slight variations will show up this way. (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 01:30 AM |
