I cant be the only one driving around, without 1st and reverse |
jsayre914 |
May 24 2009, 11:07 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I already know i need some clutch adjustment, but what a pain in the ass. Last year i was driving around with no clutch at all. (from york pa to baltimore and back again) now i got the clutch working ... thank god. Its alot easier to drive these cars with a clutch. (IMG:style_emoticons/default/biggrin.gif)
now the problem is i got all the gears apon startup, but after about 15min of driving first and reverse are no more. I cant even try to get it in without a terrible sound that says NO WAY MAN. so i start out in second and dont even try reverse. But when the car cools off again their back. (IMG:style_emoticons/default/WTF.gif) I already talked to evil, he will help me out to rebuid my tranny, but i dont have $$$ for that yet. Any tricks you guys have for me, am i the only one with temporary gearing. (IMG:style_emoticons/default/confused24.gif) |
sbonthemesa |
May 24 2009, 11:35 AM
Semi-Lurker Group: Members Posts: 35 Joined: 30-September 05 From: the mesa Member No.: 4,895 Region Association: None |
Have your tried adjusting the linkage and replacing the shifter bushings?
Rav914 |
May 24 2009, 11:37 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
What he said. You just need to adjust your linkage. A search here will yield a procedure.
Sleepin |
May 24 2009, 11:54 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Some of us aren't driving around at all! (IMG:style_emoticons/default/sad.gif)
dkjens |
May 24 2009, 12:04 PM
Member Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None |
If you really need to get in reverse, shut the engine off, shift in reverse, start the engine and do the backing up you need - if that works, for now.
jsayre914 |
May 24 2009, 12:11 PM
I never would have guessed it to be a linkage problem.
The symptoms seem to be as if trying to shift into first without using the clutch. Not a good idea. Do you really think adjusting the linkage would change that?? i will search now... |
7275914911 |
May 24 2009, 12:14 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
It does sound like you need to adjust the linkage. I would bet 4th/5th are real easy to get?
There are plenty of threads on what to do... Good Luck jkp |
PanelBilly |
May 24 2009, 12:19 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Wow, You DRIVE your car. I only work on mine!
May 24 2009, 12:24 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
And make sure both cone screws are tight. All your adjustments will be useless if they're lose ...
(IMG:style_emoticons/default/shades.gif) Andy |
So.Cal.914 |
May 24 2009, 12:42 PM
QUOTE Do you really think adjusting the linkage would change that?? If it is 1st AND R, yes. And what Andy said. |
jsayre914 |
May 24 2009, 01:13 PM
QUOTE Do you really think adjusting the linkage would change that?? If it is 1st AND R, yes. And what Andy said. it is 1st and reverse, but... when i put it into 2nd to start from a red light, the rpms choke with the gearshift in 2nd and the clutch pressed down, it wont stall but i can tell the car wants to be in neutral. |
zymurgist |
May 24 2009, 01:22 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
And make sure both cone screws are tight. All your adjustments will be useless if they're lose ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) When I had Babydoll, I thought the transmission broke when I went out for a drive. Couldn't get her into 1st gear, so I limped home starting off in 2nd (fortunately there were only a few stops). I panicked because I thought I had broken something expensive, especially since it was my job to fix Babydoll in the first place. Turned out to be a loose cone screw at the transmission end. (IMG:style_emoticons/default/driving.gif) |
jsayre914 |
May 24 2009, 01:25 PM
And make sure both cone screws are tight. All your adjustments will be useless if they're lose ... (IMG:style_emoticons/default/shades.gif) Andy (IMG:style_emoticons/default/agree.gif) When I had Babydoll, I thought the transmission broke when I went out for a drive. Couldn't get her into 1st gear, so I limped home starting off in 2nd (fortunately there were only a few stops). I panicked because I thought I had broken something expensive, especially since it was my job to fix Babydoll in the first place. Turned out to be a loose cone screw at the transmission end. (IMG:style_emoticons/default/driving.gif) when you say "couldnt get into first" did you mean it was grinding like crazy as if no clutch or you meant 1st was missing as in the gear was not there anymore?? |
zymurgist |
May 24 2009, 01:31 PM
Not there any more.
jsayre914 |
May 24 2009, 01:36 PM
Not there any more. mine is still there, but as if no clutch for these 2 gears, and thats only after driving for a little while. I really dont think its a linkage proble, but what do i know (IMG:style_emoticons/default/huh.gif) |
zymurgist |
May 24 2009, 01:45 PM
My 911 won't go into 1st... it's as if the clutch isn't releasing completely. I have a new cable, but no time to install it. My workaround is to drop it into 2nd and then move it to 1st.
jsayre914 |
May 24 2009, 05:55 PM
so... i have been searching throughout the day. It seems that more than likley i need to adust the clutch properly and run a few tests to find out if it could be synchros. I also found out that i put 40oz of the wrong fluid inside the tranny 2 weeks ago.
Lucas w/ additives 80-90 ,every thread says DO NOT USE ADDITIVES. that might be contributing to the problem too. But i would think that the wrong fluid should be better than no fluid (as it was 40 oz low) (IMG:style_emoticons/default/beer3.gif) now i gotta find a way to get the bottom drain plug (stripped) off (IMG:style_emoticons/default/idea.gif) |
ericread |
May 24 2009, 09:35 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Have you closely checked your transmission mount bolts? When I first got my 914, I "lost" first and reverse only to find the left hand transmission bolt was gone and the transmission was hanging from the right mount. Totally screwed up my linkage. Once I replaced the bolt, all was well!!! Basic rookie mistake. Now I check all my bolts quarterly.
Eric Read |
number6 |
May 24 2009, 10:01 PM
Member Group: Members Posts: 352 Joined: 14-September 08 From: portland, or Member No.: 9,546 Region Association: Pacific Northwest |
Have you checked your clutch cable? I've had 1st and reverse grind like you describe on several occasions, and it's always the cable needing to be tightened. Who knows - maybe it could be that simple (IMG:style_emoticons/default/smile.gif)
While waiting on the rebuild, have you considered just picking up a known good, used tranny? It seems people can't give them away. Heck, I have one that's in great shape that I doubt I can get $200 for. Freight sucks, of course, but there's bound to be one local to you. Good luck. -duc |
VaccaRabite |
May 24 2009, 10:48 PM
How soon after you swapped engines did this start happening?
I bet your tranny is fine, and you just need to fiddle with linkage. This is happening too soon after dropping your motor for me to suspect the tranny is the issue. I bet a bolt or cone screw has worked loose. Zach |
Lo-Fi Version | Time is now: 10th May 2024 - 02:19 PM |
