Weird Starter problem, 914 does not start when hot |
Keoni914 |
May 25 2009, 06:13 PM
Newbie Group: Members Posts: 35 Joined: 12-November 08 From: NorthEast PA Member No.: 9,746 Region Association: North East States |
This is weird but I previously thought I had a starter problem after Hershey. I stalled it while entering a parking lot on the way home and it would not start. I caught it in gear and continued home. I tried starting upon arrival, nada. Took the starter off and tested GOOD. Car starts! Went for a ride today and when we got home I thought "let me see it if starts". It didn't! Weird. About an hour later it started okay. Any thoughts on a fix???
Thanks Keoni914 |
May 25 2009, 06:21 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any thoughts on a fix??? Get a new starter. It'll only get worse from here. Some will suggest to install a "hot start" relay but that's just a band aid for a failing starter. I went to a high torque mini starter and never looked back ... (IMG:style_emoticons/default/shades.gif) Andy |
So.Cal.914 |
May 25 2009, 06:23 PM
It is actually common. And there seam to be two schools of thought that I have read. One is your starter is bad, or something else is wrong, fix the car right and it wouldn't do that. The second one, and how I took care of the problem is a 'Hot Start Kit'.
wilchek |
May 25 2009, 06:26 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
This is a really common problem. I assume when u say does not start you mean does not crank. The engine bay gets really hot and the starter get a lot of the heat. My VW Thing did the samething. They make smaller starters that some people have used. I guess the theory is that it has more airflow. They also make a thermal blanket that wraps around the starter. 914 also moved the fuel pump to the fron trunk in 75 to help as this was an issue do to the heat as well. I think the heat to the pump would help cause vapor lock.
Keoni914 |
May 25 2009, 06:29 PM
I'm learning! Thanks
Boy getting that top starter nut on in the engine bay is a real PITA also! I'll check around for a new starter! Keoni914 |
wilchek |
May 25 2009, 06:38 PM
There is a rebuilt starter in the classifieds
http://www.914world.com/bbs2/index.php?showtopic=95999 Once you know where the nut is it gets easier. The 914 has a lot of stuff like that. Wait until u work on the back brakes. |
Keoni914 |
May 25 2009, 06:47 PM
There is a rebuilt starter in the classifieds http://www.914world.com/bbs2/index.php?showtopic=95999 Once you know where the nut is it gets easier. The 914 has a lot of stuff like that. Wait until u work on the back brakes. Oh thats great to hear! (IMG:style_emoticons/default/sad.gif) I do need to rebuild the rears. Maybe I'll just send them to the Brake Guy on this forum. I got a connection to a new Parts retailer in CA, I'll ring him up for a price on a starter. (Thanks for the link though!) So far his prices are great! Keoni914 |
So.Cal.914 |
May 25 2009, 09:40 PM
Just follow the excellent write up on rebuilding the rear calipers by eric shea. You can do it! (IMG:style_emoticons/default/smash.gif) Normally I would agree with doing your own work. I do. But when it comes to your life, ask yourself "Self" "Are my mechanical skills good enough to bet our lives on it?" |
SGB |
May 25 2009, 09:43 PM
And
Eric's work is AWESOME. He will do a better job than you thought possible by humans. |
Tom |
May 26 2009, 09:29 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Hope a new starter fixes your problem, but you really should use the search function on this site and read up on what others have experienced in this area. There can be more than one problem in the start circuit. Along with different ways to "fix" those problems. If your new starter has the same heat-soak problems, then you have some wiring problems in the start circuit. Sometimes just cleaning or replacing all of the electrical connectors will solve this problem for a while. Dirt, grease and water will eventually make any connection suspect when it comes to passing current.
Hope this has been of some help. There are some good write ups in here that identify these problems. Oh, and the brakes, yep- Eric! Tom |
70Sixter |
May 26 2009, 11:50 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
It really was such a common problem that some guy made money selling a relay kit to provide more juice at hot start. Not sure but believe it is still available.
70Sixter |
May 26 2009, 11:51 AM
The other solution was to get the lug wrench/jack handle out and smite the solenoid near the starter and sometimes the starter itself. The only time my car failed to hot start (in 1988) the hammer trick worked. |
gregrobbins |
May 27 2009, 12:41 AM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Check all your electrical connections and wires. I had a similar problem and it turned out to be a corroded positive cable.
Bartlett 914 |
May 27 2009, 10:31 AM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Hope a new starter fixes your problem, but you really should use the search function on this site and read up on what others have experienced in this area. There can be more than one problem in the start circuit. Along with different ways to "fix" those problems. If your new starter has the same heat-soak problems, then you have some wiring problems in the start circuit. Sometimes just cleaning or replacing all of the electrical connectors will solve this problem for a while. Dirt, grease and water will eventually make any connection suspect when it comes to passing current. Hope this has been of some help. There are some good write ups in here that identify these problems. Oh, and the brakes, yep- Eric! Tom (IMG:style_emoticons/default/agree.gif) I went through all this. I changed the starter, I used a hot start relay, I cleaned all the connections etc. My problem was the ignition switch. I used one from a parts car but a new switch is not too expensive. Much cheaper than a new starter. Your starter may still be a problem but I suggest you go through the starter circuit first. |
SUNAB914 |
May 27 2009, 10:42 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
I agree with above! Ignition switch everytime for me. They are old and crack with heat. less expensive than a starter that is probably not your problem. Let us know what you find. IGNITION Switch!
Cap'n Krusty |
May 27 2009, 11:28 AM
Grounds. Positive wiring. Check the signal from the ignition switch. If it's there and at least 11v with the wire connected to the tab on the starter, then replace the starter. A bad starter is the answer to the question 75-80% of the time. If the switch doesn't send the signal to the starter, replace it. The Cap'n
Lavanaut |
May 27 2009, 04:55 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
I went to a high torque mini starter and never looked back ... (IMG:style_emoticons/default/agree.gif) Bought one of the Nippondenso units off eBay and never once had that happen again. Damn that was an annoying problem! (IMG:style_emoticons/default/headbang.gif) |
Drums66 |
May 27 2009, 06:18 PM
The second one, and how I took care of the problem is a 'Hot Start Kit'. that one worked for me also!! (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 8th May 2024 - 11:44 PM |
