Keoni914
May 25 2009, 06:13 PM
This is weird but I previously thought I had a starter problem after Hershey. I stalled it while entering a parking lot on the way home and it would not start. I caught it in gear and continued home. I tried starting upon arrival, nada. Took the starter off and tested GOOD. Car starts! Went for a ride today and when we got home I thought "let me see it if starts". It didn't! Weird. About an hour later it started okay. Any thoughts on a fix???
Thanks
Keoni914
May 25 2009, 06:21 PM
QUOTE(Keoni914 @ May 25 2009, 04:13 PM)
Get a new starter. It'll only get worse from here.
Some will suggest to install a "hot start" relay but that's just a band aid for a failing starter.
I went to a high torque mini starter and never looked back ...
Andy
So.Cal.914
May 25 2009, 06:23 PM
It is actually common. And there seam to be two schools of thought that I have read. One is your starter is bad, or something else is wrong, fix the car right and it wouldn't do that. The second one, and how I took care of the problem is a 'Hot Start Kit'.
wilchek
May 25 2009, 06:26 PM
This is a really common problem. I assume when u say does not start you mean does not crank. The engine bay gets really hot and the starter get a lot of the heat. My VW Thing did the samething. They make smaller starters that some people have used. I guess the theory is that it has more airflow. They also make a thermal blanket that wraps around the starter. 914 also moved the fuel pump to the fron trunk in 75 to help as this was an issue do to the heat as well. I think the heat to the pump would help cause vapor lock.
Keoni914
May 25 2009, 06:29 PM
I'm learning! Thanks
Boy getting that top starter nut on in the engine bay is a real PITA also!
I'll check around for a new starter!
Keoni914
wilchek
May 25 2009, 06:38 PM
There is a rebuilt starter in the classifieds
http://www.914world.com/bbs2/index.php?showtopic=95999Once you know where the nut is it gets easier. The 914 has a lot of stuff like that. Wait until u work on the back brakes.
Keoni914
May 25 2009, 06:47 PM
QUOTE(wilchek @ May 25 2009, 08:38 PM)
Oh thats great to hear!
I do need to rebuild the rears. Maybe I'll just send them to the Brake Guy on this forum.
I got a connection to a new Parts retailer in CA, I'll ring him up for a price on a starter. (Thanks for the link though!) So far his prices are great!
Keoni914
So.Cal.914
May 25 2009, 09:40 PM
QUOTE(esses62 @ May 25 2009, 08:24 PM)
Just follow the excellent write up on rebuilding the rear calipers by eric shea. You can do it!
Normally I would agree with doing your own work. I do. But when it comes to your life, ask yourself "Self" "Are my mechanical skills good enough to bet our lives on it?"
SGB
May 25 2009, 09:43 PM
And
Eric's work is
AWESOME.
He will do a better job than you thought possible by humans.
Tom
May 26 2009, 09:29 AM
Hope a new starter fixes your problem, but you really should use the search function on this site and read up on what others have experienced in this area. There can be more than one problem in the start circuit. Along with different ways to "fix" those problems. If your new starter has the same heat-soak problems, then you have some wiring problems in the start circuit. Sometimes just cleaning or replacing all of the electrical connectors will solve this problem for a while. Dirt, grease and water will eventually make any connection suspect when it comes to passing current.
Hope this has been of some help. There are some good write ups in here that identify these problems.
Oh, and the brakes, yep- Eric!
Tom
70Sixter
May 26 2009, 11:50 AM
It really was such a common problem that some guy made money selling a relay kit to provide more juice at hot start. Not sure but believe it is still available.
70Sixter
May 26 2009, 11:51 AM
The other solution was to get the lug wrench/jack handle out and smite the solenoid near the starter and sometimes the starter itself. The only time my car failed to hot start (in 1988) the hammer trick worked.
gregrobbins
May 27 2009, 12:41 AM
Check all your electrical connections and wires. I had a similar problem and it turned out to be a corroded positive cable.
Bartlett 914
May 27 2009, 10:31 AM
QUOTE(Tom @ May 26 2009, 10:29 AM)
Tom
I went through all this. I changed the starter, I used a hot start relay, I cleaned all the connections etc. My problem was the ignition switch. I used one from a parts car but a new switch is not too expensive. Much cheaper than a new starter. Your starter may still be a problem but I suggest you go through the starter circuit first.
SUNAB914
May 27 2009, 10:42 AM
I agree with above! Ignition switch everytime for me. They are old and crack with heat. less expensive than a starter that is probably not your problem. Let us know what you find. IGNITION Switch!
Cap'n Krusty
May 27 2009, 11:28 AM
Grounds. Positive wiring. Check the signal from the ignition switch. If it's there and at least 11v with the wire connected to the tab on the starter, then replace the starter. A bad starter is the answer to the question 75-80% of the time. If the switch doesn't send the signal to the starter, replace it. The Cap'n
Lavanaut
May 27 2009, 04:55 PM
QUOTE(SirAndy @ May 25 2009, 05:21 PM)
Bought one of the Nippondenso units off eBay and never once had that happen again. Damn that was an annoying problem!
Drums66
May 27 2009, 06:18 PM
QUOTE(So.Cal.914 @ May 25 2009, 05:23 PM)
that one worked for me also!!
