Need HELP identifying this part, Missing Cylinder Head attachment for Flashback Valve hose |
celluloid3 |
May 26 2009, 09:38 PM
Newbie Group: Members Posts: 23 Joined: 16-September 08 From: New Jersey Member No.: 9,555 Region Association: None |
Hey Everybody-
So I'm trying to find a part that's missing from my Cylinder Head on the passenger side just behind the valve. There are one on each side of the engine w/hoses that connect to the Flashback Valve, the one that is still there seems pretty securely in place leading me to believe its threaded on the end that goes into the Head/Case. It was only discovered missing after our Bear Mountain Run when Rory looked at my car. From the rough driving I had oil in the engine compartment from it splashing out in the hard turns we were taking. It must not have been there when I bought the car, because the engine was dry (don't think the previous owner ever drove it that hard) and the ride back from Massachusetts wasn't exactly curvy by any standards, so I never noticed oil spilling. It also could not have fallen out of the engine compartment with the hose attached so, that's why I think it was missing for a while... My engine is a 73 1.7L, any help Identifying and Locating this part would be really helpful. Attached is a diagram showing the part, but no number/description is listed anywhere in either of the books I have... Thanks for the help in advance, Marko Attached thumbnail(s) |
May 26 2009, 09:44 PM
Its just a piece of tubing pressed in and probably brazed in place originally.
A better and more secure way is to get two brass fittings for air hoses. One end is 1/2 or 9/16 NPT plumbing threads...the other end is the barbed end for the hose. You tap the remaining hole you have...clean up everything and thread in the new fitting. This can be done in the car... you need to take your time and remove the valve cover...put a rag under the hole to catch the aluminum pieces. Cover the tap in thick grease..take a 1/2 turn or more...then remove the tap, clean off the pieces..re-grease, and do more threading.. It takes patience...but it can be done in the car...it can be done safely...you need to think about and plan for the aluminum chips.. RIch |
celluloid3 |
May 29 2009, 02:09 PM
Its just a piece of tubing pressed in and probably brazed in place originally. A better and more secure way is to get two brass fittings for air hoses. One end is 1/2 or 9/16 NPT plumbing threads...the other end is the barbed end for the hose. You tap the remaining hole you have...clean up everything and thread in the new fitting. This can be done in the car... you need to take your time and remove the valve cover...put a rag under the hole to catch the aluminum pieces. Cover the tap in thick grease..take a 1/2 turn or more...then remove the tap, clean off the pieces..re-grease, and do more threading.. It takes patience...but it can be done in the car...it can be done safely...you need to think about and plan for the aluminum chips.. RIch Thanks Rich, I found out that the original pipe is 12mm, so I can replace it with a 12mm 1" section and braze it. Tapping the hole seems to be a bigger project left best for the winter when its in storage... Thanks again... |
ClayPerrine |
May 29 2009, 04:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 1.8L L-Jet cars did not have that tube in the heads at all. Make sure you don't have a 1.7L head on one side and a 1.8L head on the other. The valves are different.
And an easy fix is to braise the tube into the valve cover. Much easier than drilling the head. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:19 AM |
