Recommended spark plug and wires, for a '73 2.0L FI? |
jcambo7 |
May 27 2009, 01:04 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
What do you recommend for spark plug wires and spark plugs for '73 2.0 FI?
yeahmag |
May 27 2009, 01:06 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
If it's a stock ignition then stock Bosch.
jcambo7 |
May 27 2009, 01:12 PM
Cap'n Krusty |
May 27 2009, 03:02 PM
If it's a stock ignition then stock Bosch. Is their any particualr reason why you shouldn't upgrade the plugs and wires if its a stock ignition? The correct plug is the correct plug. Bosch W7 CC, or NGK B6ES. There's NO SUCH THING as an "upgrade", especially for a stock engine. Avoid platinum plugs, which have a long history of not working as well as copper plugs in air cooled engines. As for the wires, I use a Beru set made for a 912. Beru is OE, Bosch is not. 2.0 engines don't use the same wires as 1.7/1.8 engines, as the plugs are farther away from the distributor. The Cap'n |
WFG |
May 27 2009, 08:23 PM
Newbie Group: Members Posts: 29 Joined: 6-December 05 From: nashville tenn 37076 Member No.: 5,243 |
WFG |
May 27 2009, 09:07 PM
bosch plugs are not a good idea unless you want to change plugs all the time. they are the lowest cost plug out there. ngk are great plugs. but i have had the best service with ac delco. have been running them since 1979 less chance of fouling out.
Lo-Fi Version | Time is now: 10th May 2024 - 08:11 AM |
