QUOTE(jcambo7 @ May 27 2009, 12:12 PM)
QUOTE(yeahmag @ May 27 2009, 02:06 PM)
If it's a stock ignition then stock Bosch.
Is their any particualr reason why you shouldn't upgrade the plugs and wires if its a stock ignition?
The correct plug is the correct plug. Bosch W7 CC, or NGK B6ES. There's NO SUCH THING as an "upgrade", especially for a stock engine. Avoid platinum plugs, which have a long history of not working as well as copper plugs in air cooled engines. As for the wires, I use a Beru set made for a 912. Beru is OE, Bosch is not. 2.0 engines don't use the same wires as 1.7/1.8 engines, as the plugs are farther away from the distributor.
The Cap'n
