using 911 rear solid rotors on a 914-6? |
thesey914 |
May 28 2009, 08:45 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Is it possible to run these with stock callipers? I had it in my mind that early 911 rears are similar to the 914-6 rears.
I know the 911 has internal parking brake shoes but I thought the actual braking surface with essentially the same? |
Project 6 |
May 28 2009, 08:53 AM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
Is it possible to run these with stock callipers? I had it in my mind that early 911 rears are similar to the 914-6 rears. I know the 911 has internal parking brake shoes but I thought the actual braking surface with essentially the same? Which stock calipers? /4 or /6? And why would you want to? /6 rotors are easy to find. They are used on most if not all five lug conversions. /4 calipers will work with a little bit of effort and will take /6 solid and vented ones as well. The vented rears will need a spacer between the caliper halves. The expert on brakes is Eric at PMBPerformance.com His Momz dresses him funny but he's a good guy. (IMG:style_emoticons/default/cheer.gif) |
dr914@autoatlanta.com |
May 28 2009, 10:20 AM
914 Guru Group: Members Posts: 7,842 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Is it possible to run these with stock callipers? I had it in my mind that early 911 rears are similar to the 914-6 rears. I know the 911 has internal parking brake shoes but I thought the actual braking surface with essentially the same? you could but the offset is different so you would have to space the calipers with washers. I would just buy original six rear rotors commonly available for 95.00 each and install those |
Lo-Fi Version | Time is now: 10th May 2024 - 12:36 AM |
