The Weather is here, wish you were beautiful..., Time to start working on z' car |
djm914-6 |
Mar 3 2004, 11:32 AM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
So, I's got oil leaks like crazy. I'll follow one Club members idea and call a local Hose manufacturer for the line from oil tank filler to top of engine. I think I'll also go with the rubber type valve cover gaskets. Aside from those two areas, where else should I start looking? Any tips on this subject mater?
Next is heat. I like to drive sans top as much as possable. Here in New England, that means having some form of heat. I think I can get the passenger side HE hooked up pretty easily. My mechanic used a large braded line from the oil tank to the motor instead of the factory bent steel line when the Rich Johnson mount was installed. Any ideas on why the stock heating system won't fit as he told me? Thanks all, |
Lo-Fi Version | Time is now: 27th May 2024 - 02:04 PM |
