QUOTE(djm914-6 @ Mar 4 2004, 09:11 AM)
Can you translate that into Redneck English please.
i'll try, not sure which term you're having trouble with tho...
the Turbo (finned) valve covers are much more rigid and won't warp (and leak) like stockers. the fins might help cooling a bit, doubt it's significant. but the fins will interfere with the trailing arm makiing them impossible to install unless you modify something. i think you need to mill or belt-sand about 1/4" off the fins. i have got my VC gasket sets from Paragon, i'm pretty sure everybody's got 'em. i replaqced my intake VC's too (the actual cover...) at astonishing cost - they've recently gone up A LOT - significantly more than the torbo exhaust VC's for no reason i can imagine...
on engines as old as ours the cam oil lines can experience separation of the rubber from the metal ferrule fittings. they're not expensive. while you're replacing oil lines, consider replacing the adapter fitting (thing the oil line banjo bolt screws into) with the later Turbo part - restricts a bit of oil from the cam area and helps improve oil pressure. i'll have to post the specific part numbers when i'm back closer to my references...
the rest i figure you've previously encountered (lemme know otherwise). oh - your car doesn't have injection pump oil supply or drainback fittings :-) ...
othjer standard 911 leak places - oil pressure sensor, oil temp sender, thermostat, breather fitting. and check the breather from the oil tank to the air cleaner - if that's loose, the oil that's supposed to hide in your air cleaner element will leak out instead ...
