look Ma Iam earless, Hellhole revisited |
bernbomb914 |
Mar 3 2004, 05:19 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
A few pics to show whats involved in fixing the suspension ear in the hell hole. now I know why Brad charges $1500.00 to fix. $395.00 worth of parts from design restoration.
Bernie Attached image(s) |
bernbomb914 |
Mar 3 2004, 05:20 PM
xxx
bernbomb914 |
Mar 3 2004, 05:21 PM
xxx
bernbomb914 |
Mar 3 2004, 05:22 PM
xxx
bernbomb914 |
Mar 3 2004, 05:23 PM
xxx
bernbomb914 |
xxx
bernbomb914 |
Mar 3 2004, 05:24 PM
last one
Jeff Bonanno |
Mar 3 2004, 06:12 PM
il dottore Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 |
yipes! (IMG:style_emoticons/default/blink.gif)
bernbomb914 |
Mar 3 2004, 06:33 PM
It shows that it had been repaired before in the same place. Untill I removed the motor I had no idea that it had this much rust. Check your area carefully as it could hurt if it failed at the wrong time. It will be as good as new when we are done.
Bernie |
watsonrx13 |
Mar 3 2004, 09:10 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Bernie, I'll be doing the same procedure in a couple of months, please describe, in detail, the process you're doing. Also, post pics larger, if you can. Thanks for any help you can provide.
Looking good.... (IMG:style_emoticons/default/smilie_pokal.gif) |
bernbomb914 |
Mar 3 2004, 09:30 PM
rob email me your address and I will send the pic full size
bernie@iinet.com |
john rogers |
Mar 3 2004, 09:52 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Good job so far! Don't you just love welding in those sort of places? I had to do some repairs on my race car and it sure is a pain to weld upside down!
Gint |
Mar 3 2004, 11:16 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Looking good Bernie. At least now you can get in there and fix it up for good.
RustyWa |
Mar 3 2004, 11:35 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I agree, bigger pics. 640x480 minimum. Unfortunately, even with higher resolution monitors, 640x480 look like postage stamps.
bernbomb914 |
Mar 4 2004, 12:18 PM
changed the picure size
Bernie |
watsonrx13 |
Mar 4 2004, 05:49 PM
Bernie, did you order the ear and the engine shelf from design-restorations?
Other than drilling out the spot welds on the bad ear and engine shelf was there any 'fab' work you needed to do? Thanks again for the post and increasing the pic size. |
Chris914n6 |
Mar 4 2004, 09:03 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Looks like ear replacement was the good choice. Bummer it had to be done.
Thanks for the pics & update. |
bernbomb914 |
Mar 4 2004, 10:59 PM
we are going to repair all the rust damage with patches put in a new batt. box and the metal strip that holds the rubber seal on thaat side. I will take more Pics as we go. I hope it will help the next person that has to do this.
Bernie |
bernbomb914 |
Mar 16 2004, 10:59 PM
more pics on the install of the ear Battery box and seal
my sons did the work we were a little short on electricty as we had to drag it about 75 feet with a large extension cord. that made it hard to get a good flow with our welder. more pics to follow Bernie Attached image(s) |
bernbomb914 |
Mar 16 2004, 11:00 PM
xxxx
Lo-Fi Version | Time is now: 13th May 2024 - 02:37 AM |
