there goes HOPE that my engine will survive!, damn 1000 mile heads my A$$ !! |
degreeoff |
Jun 8 2009, 07:57 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
well just pulled leak down numbers and as explained here.....
http://forums.pelicanparts.com/showthread....leakdown+tester I bought the same tester. I was pulling readings of 13% with a couple @ 17 and 21....this was on a COLD engine...I know a no no but its all I had?? two of my cylinders had a 'strange sound from the head area....squirted alittle oil down the chute and walla bubbles around my valve....WTF??? is this an easy fix (new guides I presume? with a small home machine shop can I do this? Anyone...anyone? BTW were my leak down numbers way off? thanks Josh AND Andy plzzz dont say I told you so eh! |
SLITS |
Jun 9 2009, 02:20 PM
You would need a mill and fabricate a jig to hold the head in the correct postion to drill the hole for the valve guide. It has to be indexed correctly.
You can buy oversize valve guides. I do not know the tolerances for a press fit on the guides. After installation, you might have to hone the guides to the correct size. It should be obvious that I have not done this procedure. May be cheaper in the long run to let a qualified shop replace the guides (if that's what is wrong). You might also want to check and see if the head is cracked thru the guide boss. |
sww914 |
Jun 9 2009, 08:18 PM
You can probably do the guides in your garage if you're 1 in 100, but most guys couldn't. The expense of setting up to do it will be much more than what it will take to pay a machinist to do it.
Those HF leakdown testers aren't accurate at all. They give you a relative number that you can compare like a compression tester, not like a real leakdown tester. Those numbers are about the same as an engine that I tested with a fresh top end, rings not seated. How is it running? What prompted you to test it? What engine is it? |
Dr Evil |
Jun 9 2009, 08:44 PM
I know of 2 shops that I trust if you need. They are not very expensive and do a good job, but they are not in your hood. I understand how to replace the valve guides and I would not do it myself (IMG:style_emoticons/default/wink.gif)
degreeoff |
Jun 9 2009, 09:59 PM
Hi Steve,
Give you an idea I put a 100psi gauge on the el cheapo side of the HF item and was coming up with 5% @ 100 psi in. It runs good but smokes too much. I can feel the 'lack of" compression whilst coasting in gear....it feels like I am coasting more than I would have in my old 2056, and I have 9.5 to 1 comp in this one. I have 4 autoX's and about 15 hours of run time on the engine. I may need to make the drive up there Mike if I find that I take it apart and find the guides to be bad.......how many smackers are we talking? specs are GE 40 cams, Ross 9.5/1 pistons, headers, electromotive crankfire ignition and PMO's |
Lo-Fi Version | Time is now: 19th May 2024 - 04:16 PM |
