Front turn signals - installing new boots, Help needed with wiring |
Pat Garvey |
Jun 8 2009, 08:13 PM
OK, I admit it - I took something apart with no notes or pics.
So, after nearly 2 years of ill health & lack of interest, I'm ready to renew. Bought new front signal boots a while ago because the old ones disintegrated (literally). Took thew buckets out to refurbish, but didn't note the wiring hookup. So, I have buckets with the following markings - "57", "31", and "BL". Also have a gang of wires exiting the old boots. Yeah, I could look it up, but thought it would be more fun to take a bashing! What wires go where? Pat |
Pat Garvey |
Jun 10 2009, 07:55 PM
Hello?
JeffBowlsby |
Jun 11 2009, 02:19 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached thumbnail(s) |
Jasfsmith |
Jun 12 2009, 08:45 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
MDG |
Jun 12 2009, 11:15 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Great to hear your juices are flowing (IMG:style_emoticons/default/smilie_pokal.gif)
Pat Garvey took something apart without copious notes!?! What the . . ??? I find myself feeling disillusioned, confused. I think I'll go wander aimlessly around for a bit. What's next - a Porsche badge on the front trunk!? |
Johny Blackstain |
Jun 12 2009, 12:09 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I just did this job to the LE last summer & found it to be a bitch. I wound up bathing the new boots w/ armour all, inside & out & that made the job much easier.
Pat Garvey |
Jun 12 2009, 07:46 PM
Thank you Jeff. Saved me some research. You do man! Both side go on tomorrow morning. Whew! Pat |
Pat Garvey |
Jun 12 2009, 07:51 PM
I just did this job to the LE last summer & found it to be a bitch. I wound up bathing the new boots w/ amour all, inside & out & that made the job much easier. Armorall? You'd use Armorall on perfectly good German rubber? Why didn't you use glycerin, or KY (works too & excites me). Armorall on good quality German rubber is like using Castrol GT 40 to lube a condom. Starts rotting the rubber as soon as it touches it. Pat |
Pat Garvey |
Jun 12 2009, 07:52 PM
Great to hear your juices are flowing (IMG:style_emoticons/default/smilie_pokal.gif) Pat Garvey took something apart without copious notes!?! What the . . ??? I find myself feeling disillusioned, confused. I think I'll go wander aimlessly around for a bit. What's next - a Porsche badge on the front trunk!? In the words of John McCain - "I screwed up". Pat |
Pat Garvey |
Jun 23 2009, 07:11 PM
I just did this job to the LE last summer & found it to be a bitch. I wound up bathing the new boots w/ amour all, inside & out & that made the job much easier. I find myself humbled! How do you get the wires out of the side marker boot(SMB) without destroying the boot, which is just fine? I've been going in from the top (turn signal assy removed). Now, can you put enough "juice" on the SMB to extract the wires & connectorrs without destroying the boot? Can you do it one at a time? I don't want to snip the wires & get a new boot if I don't have to. What'd you do JB. Pat |
Johny Blackstain |
Jun 27 2009, 09:38 AM
I find myself humbled! How do you get the wires out of the side marker boot(SMB) without destroying the boot, which is just fine? I've been going in from the top (turn signal assy removed). Now, can you put enough "juice" on the SMB to extract the wires & connectorrs without destroying the boot? Can you do it one at a time? I don't want to snip the wires & get a new boot if I don't have to. What'd you do JB. Pat Sorry to take so long to get back to you Pat, PC blew up again. (IMG:style_emoticons/default/blowup.gif) This is a new one I just built; $ (IMG:style_emoticons/default/headbang.gif) $ I took everything apart, cleaned & replaced all sorts of rubber George should have replaced 6 yrs ago. (IMG:style_emoticons/default/chair.gif) My old boots & backs of my TS assemblies were covered in 35 yrs old undercoating. When I did this the car was up on jacks, assy. removed, wheel off, I came in from the wheel well & daylight was shining through the holes for the turn signals. Old rubber was so ugly w/ undercoating it would have destroyed them to clean so I just cut them off & replaced w/ new ones from George. I did not snip the wires, I snipped the rubber boots. After cleaning the wires I found it beyond difficult to put it back together w/out lube & I wanted a lube I know evaporates & goes away, hence the armorall. Wiped them clean & masked them up so I could apply new undercoating, properly. As you know, my Dad's car was undercoated @ the dealer so concours-wise the car should match the paperwork. After the stuff was dry I put the signals & wires back, all clean & shiny w/ no overspray & new boots all around. I re-crimped the spade connectors for strength, sprayed the rubber w/ the "magic liquid", shoved the spades into their respective holes & fished them out using needle nose pliers. Most importantly I did one side @ a time so I would not have to bother w/ remembering or marking which wire went where... (IMG:style_emoticons/default/biggrin.gif) PS- "armour all" was meant to get your attention & obviously it did (IMG:style_emoticons/default/happy11.gif) |
Pat Garvey |
Jun 29 2009, 08:04 PM
I find myself humbled! How do you get the wires out of the side marker boot(SMB) without destroying the boot, which is just fine? I've been going in from the top (turn signal assy removed). Now, can you put enough "juice" on the SMB to extract the wires & connectorrs without destroying the boot? Can you do it one at a time? I don't want to snip the wires & get a new boot if I don't have to. What'd you do JB. Pat Sorry to take so long to get back to you Pat, PC blew up again. (IMG:style_emoticons/default/blowup.gif) This is a new one I just built; $ (IMG:style_emoticons/default/headbang.gif) $ I took everything apart, cleaned & replaced all sorts of rubber George should have replaced 6 yrs ago. (IMG:style_emoticons/default/chair.gif) My old boots & backs of my TS assemblies were covered in 35 yrs old undercoating. When I did this the car was up on jacks, assy. removed, wheel off, I came in from the wheel well & daylight was shining through the holes for the turn signals. Old rubber was so ugly w/ undercoating it would have destroyed them to clean so I just cut them off & replaced w/ new ones from George. I did not snip the wires, I snipped the rubber boots. After cleaning the wires I found it beyond difficult to put it back together w/out lube & I wanted a lube I know evaporates & goes away, hence the armorall. Wiped them clean & masked them up so I could apply new undercoating, properly. As you know, my Dad's car was undercoated @ the dealer so concours-wise the car should match the paperwork. After the stuff was dry I put the signals & wires back, all clean & shiny w/ no overspray & new boots all around. I re-crimped the spade connectors for strength, sprayed the rubber w/ the "magic liquid", shoved the spades into their respective holes & fished them out using need nose pliers. Most importantly I did one side @ a time so I would not have to bother w/ remembering or marking which wire went where... (IMG:style_emoticons/default/biggrin.gif) PS- "armour all" was meant to get your attention & obviously it did (IMG:style_emoticons/default/happy11.gif) It worked - you got my attention! Well, I've spent enough on boots, & my TS boots are good, so I'll just snip & replace the connectors, while sparing the boot. Thanks! Pat |
Johny Blackstain |
Jun 30 2009, 09:35 AM
Pat Garvey |
Jun 30 2009, 08:11 PM
It worked - you got my attention! Well, I've spent enough on boots, & my TS boots are good, so I'll just snip & replace the connectors, while sparing the boot. Thanks! Pat I'd advise against that Pat- wires are short enough as they are. Agreed, they are short (very short). I suspect that the factory had bare wires that they moved through a number of boots on these cars, then connected connectors when through the boots. I'm anal enough that I'd like to keep all origional connectors (& have so far), but I don't see a way from this problem. I could buy new boots, but what would that solve? And my current boots are just fine. Waht did you do? Pat |
Johny Blackstain |
Jul 1 2009, 01:38 PM
Agreed, they are short (very short). I suspect that the factory had bare wires that they moved through a number of boots on these cars, then connected connectors when through the boots. I'm anal enough that I'd like to keep all origional connectors (& have so far), but I don't see a way from this problem. I could buy new boots, but what would that solve? And my current boots are just fine. Waht did you do? Pat I had to cut my boots cause they were pretty much gone & covered in undercoating. In your shoes I'd try comming in from the wheel well, greasing the crap out of the boots & wires & try to wiggle one wire @ a time through the boot holes using needle nose pliers. I would use this method for both assembly & disassembly. |
PanelBilly |
Jul 2 2009, 04:49 PM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I was able to pull the connectors through the rubber. I just did one at a time took them off a few years ago and last weekend put them back in.
PanelBilly |
Jul 2 2009, 04:51 PM
One important step I left out. You need to wisper dirty words to the rubber first. so the natural loosening effect takes action
Pat Garvey |
Jul 5 2009, 08:21 PM
One important step I left out. You need to wisper dirty words to the rubber first. so the natural loosening effect takes action That's the thing I was missing! Tried & tried, just with the wires for the side markers - wouldn't budge! So I talked to them (or was it me) in no uncertain filthy words that they would go through the boot, or I would have my way with them! Oh yeah, they got the word. Little more glycerin & poom! Slid right through! Still working on the big cable for the bucket, though will talk dirtier tomorrow & promise hemmies if it doesn't go through. I think the wiring harness is quaking right now, maybe even a pucker. Yeah, you CAN control these German beasts when you talk dirty....and threaten. Pat |
Lo-Fi Version | Time is now: 4th May 2024 - 05:17 PM |
