Most interesting failure I've seen yet |
sww914 |
Jun 12 2009, 12:56 PM
One of the 911 racecars that I maintain came in with a slipping clutch. I had just seen the clutch 2 events before and it was still 75% there. I noticed 2 other things about the car, the clutch pedal felt funny and the outside door handle was broken. I went to investigate the stiff clutch pedal and after I removed the floor board I saw a shiny silver pin stuck under the clutch area of the pedal cluster. With some pliers I removed it and it was the long pin on 911 door handles that always breaks. It had wedged it's self under the pedal cluster in such a way as to prevent the clutch pedal from returning all the way and forcing the clutch to slip.
We're putting a new clutch in anyway just because he spends so much money to get to the track that it's not worth taking a chance but I bet we could run this clutch. So, I can't believe it but the door handle broke and took out the clutch! |
914Sixer |
Jun 12 2009, 01:05 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just plain WIERD!!!!
EdwardBlume |
Jun 12 2009, 01:08 PM
Yep. Good work Quincy! (IMG:style_emoticons/default/aktion035.gif)
6freak |
Jun 12 2009, 01:23 PM
Murphy strikes again
Lo-Fi Version | Time is now: 20th May 2024 - 02:03 AM |
