> WEVO Transmission Mounts, Second opinion on my install...
Zimms
post Jun 19 2009, 07:24 PM
Post #21
Just want to know if this is correct. They were easy to install, but there was no cursing or round II that I normal go through, so the whole thing feels weird. Here is what the installed mount looks like. Is this correct?
Thanks!
Zimms   WEVO Transmission Mounts   Jun 19 2009, 07:24 PM
lotus_65   never looked at one up close. looks really nice...   Jun 19 2009, 07:55 PM
McMark   Looks good. I'd take the time to get some app...   Jun 19 2009, 08:11 PM
J P Stein   Looks like mine.....after I tightened things up. I...   Jun 19 2009, 08:52 PM
914_teener   These look great. Let me know what the "soun...   Jun 19 2009, 10:33 PM
iamchappy   I would still use the cup washer that prevents it ...   Jun 19 2009, 10:42 PM
Zimms   I would still use the cup washer that prevents it...   Jun 20 2009, 03:02 PM
tat2dphreak   execpt when you write the check...   Jun 19 2009, 10:48 PM
McMark   execpt when you write the check... Let me know ...   Jun 20 2009, 02:04 PM
tat2dphreak   execpt when you write the check... Let me know...   Jun 20 2009, 02:43 PM
tat2dphreak   execpt when you write the check... Let me know...   Jun 23 2009, 09:07 AM
GeorgeRud   I installed mine when they first came out, and the...   Jun 19 2009, 11:04 PM
Dr Evil   I second that you should use the big cup washer on...   Jun 19 2009, 11:31 PM
SirAndy   I second that you should use the big cup washer o...   Jun 20 2009, 02:13 PM
Zimms   Thanks everyone. I am going to add the big washer ...   Jun 19 2009, 11:59 PM
brp986s   It seems there should be material around the tabs....   Jun 20 2009, 02:28 PM
J P Stein   I'm not gonna add the big washer. I'll let...   Jun 20 2009, 03:30 PM
iamchappy   I used the stock thick washer that was there befor...   Jun 20 2009, 05:58 PM
Zimms   My old mounts just went straight into the rubber m...   Jun 21 2009, 07:43 AM
Cap'n Krusty   Better go back and get 4 8mm bolts 10 mm longer, a...   Jun 23 2009, 09:52 AM
Larmo63   I'm looking at the Wevo transmission mounts to...   May 2 2019, 10:11 PM
porschetub   Using the solid 911 "sport" mounts ,so f...   May 2 2019, 10:30 PM
Luke M   I have a set of the Wevo blue trans mounts that I...   May 3 2019, 06:07 AM
mb911   I have a set of the Wevo blue trans mounts that I...   May 3 2019, 06:08 AM
campbellcj   I have the Wevo blue ones and have been very happy...   May 3 2019, 07:41 AM
Larmo63   The black pads are softer. I'm going to go to ...   May 3 2019, 08:28 AM
- Lo-Fi Version Time is now: 11th July 2025 - 05:26 PM
