wheel filler prior to painting; what to use |
tod914 |
Jun 20 2009, 12:03 AM
I just had a set of Mahles soda blasted. There is some minor scratches that need to be filled. Anyone have any suggestions of what would be a good product for that?
Wes V |
Jun 20 2009, 09:07 AM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
Since it's going to be painted, I think I'd just use JB Weld. Be sure to finish shape it prior to it's getting too hard.
Wes |
tod914 |
Jun 20 2009, 12:07 PM
Great thanks Wes.
geniusanthony |
Jun 21 2009, 01:47 AM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
I would think that for minor scratches some high build primer and sanding will fill fine.. JB seems overkill.. for deeper scratches all-metal or similar would seem better than JB also probably easier to sand as well and adhere just as well.
Mikey914 |
Jun 21 2009, 01:52 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Use high temp Labmetal, it is good to over 500 Degrees so you can even powder coat it.
GeorgeRud |
Jun 21 2009, 09:34 AM
This is the first I've heard of Lab Metal. Where do you buy it? I only saw industrial suppliers selling it by the case.
underthetire |
Jun 21 2009, 12:38 PM
Spot putty works fine. Iv'e even seen the custom guys bondo the wheels. They flex less than the body does. Seems to hold up fine.
Mikey914 |
Jun 21 2009, 05:05 PM
Right here:
http://www.alvinproducts.com/Products/Products.asp?id=2 Works great! The only way to go for powdercoating. |
charliew |
Jun 21 2009, 07:31 PM
The lab metal is pretty expensive to be using for a painted wheel. If I were just putting a good bc cc on the wheel I would make sure it's real clean and use epoxy two part primer then a sanding primer or rage body filler in the scratches then more sanding primer then the sealer and the bc/cc. Just like a normal good auto application.
If it's going to be a powder coat then jb weld or labmetal. |
Pat Garvey |
Jun 21 2009, 07:35 PM
Wes V |
Jun 21 2009, 09:08 PM
Since it's going to be painted, I think I'd just use JB Weld. Be sure to finish shape it prior to it's getting too hard. Wes Ummm, excuse me, but why would you paint these wheels? Pat Why are you quoting me, when it's tod914 that is painting his wheels?? Wes |
tod914 |
Jun 21 2009, 11:56 PM
Thought they are suppose to be that Wurth silver, no?
Lo-Fi Version | Time is now: 15th May 2024 - 12:28 PM |
