tod914
Jun 20 2009, 12:03 AM
I just had a set of Mahles soda blasted. There is some minor scratches that need to be filled. Anyone have any suggestions of what would be a good product for that?
Wes V
Jun 20 2009, 09:07 AM
Since it's going to be painted, I think I'd just use JB Weld. Be sure to finish shape it prior to it's getting too hard.
Wes
tod914
Jun 20 2009, 12:07 PM
Great thanks Wes.
geniusanthony
Jun 21 2009, 01:47 AM
I would think that for minor scratches some high build primer and sanding will fill fine.. JB seems overkill.. for deeper scratches all-metal or similar would seem better than JB also probably easier to sand as well and adhere just as well.
Mikey914
Jun 21 2009, 01:52 AM
Use high temp Labmetal, it is good to over 500 Degrees so you can even powder coat it.
GeorgeRud
Jun 21 2009, 09:34 AM
This is the first I've heard of Lab Metal. Where do you buy it? I only saw industrial suppliers selling it by the case.
underthetire
Jun 21 2009, 12:38 PM
Spot putty works fine. Iv'e even seen the custom guys bondo the wheels. They flex less than the body does. Seems to hold up fine.
Mikey914
Jun 21 2009, 05:05 PM
Right here:
http://www.alvinproducts.com/Products/Products.asp?id=2Works great! The only way to go for powdercoating.
charliew
Jun 21 2009, 07:31 PM
The lab metal is pretty expensive to be using for a painted wheel. If I were just putting a good bc cc on the wheel I would make sure it's real clean and use epoxy two part primer then a sanding primer or rage body filler in the scratches then more sanding primer then the sealer and the bc/cc. Just like a normal good auto application.
If it's going to be a powder coat then jb weld or labmetal.
Pat Garvey
Jun 21 2009, 07:35 PM
QUOTE(Wes V @ Jun 20 2009, 09:07 AM)
Wes
Ummm, excuse me, but why would you paint these wheels?
Pat
Wes V
Jun 21 2009, 09:08 PM
QUOTE(Pat Garvey @ Jun 21 2009, 06:35 PM)
Wes
Pat
Why are you quoting me, when it's tod914 that is painting his wheels??
Wes
tod914
Jun 21 2009, 11:56 PM
Thought they are suppose to be that Wurth silver, no?
