Farewell 504? |
Farewell 504? |
EdwardBlume |
Jun 21 2009, 02:43 PM
I'm almost done deboning the chicken and I'm debating finding someone with race car aspirations, or else recycling this sucker. It got to go though, as I'll be rebuilding my street car soon (?).
So what do you think? Crush it Cut it Find someone who wants it Turn it into art? |
EdwardBlume |
Jun 21 2009, 02:44 PM
Some picts
Attached thumbnail(s) |
EdwardBlume |
Jun 21 2009, 02:45 PM
More
EdwardBlume |
Jun 21 2009, 02:47 PM
Good long, repaired jack posts, center tube, former AC car, battery area needs work, oh and the entire front end...
pktzygt |
Jun 21 2009, 02:52 PM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
Ship it to the east coast!
tat2dphreak |
Jun 21 2009, 03:11 PM
it's NOT that bad... someone could totally bring that back to life... or could use the few parts left. fuchs look to be in good shape...
Jun 21 2009, 03:25 PM
Trailer....think about it....
Rich |
Derek Seymour |
Jun 21 2009, 03:27 PM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
once again I wish I had storage area (IMG:style_emoticons/default/headbang.gif) ... that's got race car written all over it (IMG:style_emoticons/default/driving.gif)
EdwardBlume |
Jun 21 2009, 03:52 PM
rudedude |
Jun 21 2009, 04:05 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Thats way way way better than the one I am or was going to repair.
Why are you so far away? Jule |
JeffBowlsby |
Jun 21 2009, 04:30 PM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
orange914 |
Jun 21 2009, 08:18 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
someones gotta find this cali. car worth shipping. it's a shame to cut it up (IMG:style_emoticons/default/barf.gif)
jmill |
Jun 21 2009, 10:21 PM
How far does the damage go up front? If it's past the bulkhead it's a ton of work to get straight again. I voted to save it anyhow. I bought a wrecked one myself but the damage wasn't quite as bad as that.
EdwardBlume |
Jun 21 2009, 10:22 PM
Ha ha Jeff, where did you dig out this old picture of me? and that was after I mowed the mullet... |
Gunther |
Jun 21 2009, 10:26 PM
Racer from birth Group: Members Posts: 50 Joined: 1-June 09 From: Charlotte, NC area Member No.: 10,429 Region Association: South East States |
once again I wish I had storage area (IMG:style_emoticons/default/headbang.gif) ... that's got race car written all over it (IMG:style_emoticons/default/driving.gif) 24 hours of Lemons (IMG:style_emoticons/default/driving.gif) At least. Nothin a BIG hammer can't fix. (IMG:style_emoticons/default/smash.gif) |
EdwardBlume |
Jun 21 2009, 10:42 PM
I guess I can describe it better....
The front was hit hard enough to pull the A arms about 2 inches together. It didn't help that is was an AC car with holes. Both fenders are toast. Inside the trunk, the wheel wells are bent. Therefore, it needs to get some bench time at least enough to get the A arm front mount straight. Gas tank area back is fine. Wheel wells were sprayed at one point. AC holes along the pass side up under the battery. Battery area is what you see. Looks like the metal was treated at one time. Doors are gone. Interior is gone. Engine / Tranny gone. Wiring gone. If it wasn't welded on, its gone. Jack posts were problems at one point, then patched. Accelerator tube was broken at one point and fixed. The rest of the paint / body I believe was a McMark job, and it was a very nice job (IMG:style_emoticons/default/aktion035.gif) . As it sits now, there's numerous scratches (like keying) on the fenders and rear trunk. The rear trunk took an odd impact too that pushed one corner about 1 cm. Body there is OK. Inside trunk is solid but looks like it was treated. No holes except two 1/2 holes I drilled to hold the half shafts up. Center tube was cut in the rear to take the wiring out easier. If it is indeed heading for the big recycler in the orient, the Fuchs, 4 adjustable Konis, ? rear springs, newer 21MM sway bar, calipers, ss brake lines, steering column, and trailing arms will be taken off. On a brighter note, the floors, longs, jambs, windshield, dash are great - hence the hesitation. I have a CA junk title in my name... The way this poll is going, I'm likely going to have to give the ole' college try to find another owner.... |
carr914 |
Jun 22 2009, 06:39 AM
Racer from Birth Group: Members Posts: 118,626 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I voted find someone to use it, but if you cut it, I need a section of passenger floor to use as a patch (IMG:style_emoticons/default/welder.gif)
T.C. |
rick 918-S |
Jun 22 2009, 09:05 AM
Hey nice rack! -Celette Group: Members Posts: 20,457 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Very, Very repairable. And your fenders look repairable even with the slice across the end of the right one. This car is still on the fence due to the amount of rust it has. The problem is the added cost of shipping a car that doesn't run. (or roll and steer very good..) But I say someone should fix it.
McMark |
Jun 22 2009, 11:47 AM
Rob, if you feel like delivering it, you can drop it off at my shop anytime. I'll gladly throw it in my storage yard for a rainy day. (IMG:style_emoticons/default/cool.gif)
EdwardBlume |
Jun 22 2009, 12:37 PM
Rob, if you feel like delivering it, you can drop it off at my shop anytime. I'll gladly throw it in my storage yard for a rainy day. (IMG:style_emoticons/default/cool.gif) Done. You rock Mark! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 12:35 PM |
