Headlight assembly |
PanelBilly |
Jun 23 2009, 08:26 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Pull the headlight wires into the bucket These are the headlight wires without the plastic shield on them. Connect the works of the headlight hardaware to the cover |
PanelBilly |
Jun 23 2009, 08:31 PM
Screw in the stop bolt. Clean the threads before and it will adjust much easier to make adjustments
Screw in the lock bolt on the back side If you painted the car, clean the ground connection. Note on newer models it is a clip on fitting |
PanelBilly |
Jun 23 2009, 08:39 PM
Push on the rubber shield for the turn light and side light wires. Pull them through
Slip the headlight cover assembly into the bucket. Note that it slips into a notch toward the outside of the car first. Secure with plate and screws in fender well The secure the inside pivot |
PanelBilly |
Jun 23 2009, 08:48 PM
Slip the boot on the back of the bucket and push the bar though from the back. Connect it to the pivot point on the headlight assembly.
Push the relay socket into place While holding the plate that the boot fits to in place, put the motor in place. You either need three hands here or be good at multitasking. |
PanelBilly |
Jun 23 2009, 08:57 PM
Locate the headlight cover in the closed position and tighten the center bolt with the bar in the farthest point in rotation. Connect your wires.
Screw on the headlight shields and the black covers on the inside of the trunk. all done. Attached image(s) |
6freak |
Jun 24 2009, 01:53 PM
RIGHT ON BILLY ... (IMG:style_emoticons/default/piratenanner.gif) let me know if you need a hand with anything
....You mite want to stop though i seen a blemish in the paint so you have to sand down the whole car and respray it (IMG:style_emoticons/default/poke.gif) |
PanelBilly |
Jun 24 2009, 02:30 PM
Hey one of the headlight covers hasn't been cut and buffed yet! I'll need to go back and do that after a few months.
FourBlades |
Jun 24 2009, 02:53 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
That is a great sequence of pictures.
Your car looks super nice.... (IMG:style_emoticons/default/drooley.gif) Classic thread???? John |
RiqueMar |
Jun 24 2009, 02:57 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Nice. Hey, what year is your car? I only ask because I tried to put on those late rubber boots that I grabbed off a 75', but it wouldn't fit on my 70'?
PanelBilly |
Jun 24 2009, 11:41 PM
tod914 |
Jun 24 2009, 11:55 PM
Awesome job Billy. Can't wait to see the finished car. Dig the white head lamp covers too.
Strudelwagon |
Jul 2 2011, 09:12 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
Thanks Billy,
I was scratching my head a bit and then I found your thread. Huge help (IMG:style_emoticons/default/pray.gif) SW |
smveril |
Apr 16 2012, 06:31 PM
Mikey Group: Members Posts: 50 Joined: 6-December 04 From: Cincinnati, OH Member No.: 3,232 Region Association: Upper MidWest |
Eric_Shea |
Apr 16 2012, 07:36 PM
For the most part. How about the armature? 1st and 3rd pictures in Post #4. 1st picture in post #5. You'll also need backing plates and M6 Hex caps. Pictures 2 and 3 in post #3
Lo-Fi Version | Time is now: 16th May 2024 - 08:16 AM |
