Rim fitment |
Rim fitment |
Ltr450Cam |
Jun 25 2009, 01:26 PM
Newbie Group: Members Posts: 2 Joined: 24-June 09 From: CA Member No.: 10,503 Region Association: Southern California |
What is the max rim size without rolling the fenders and with rolling them. I couldn't find anything on google
tat2dphreak |
Jun 25 2009, 01:35 PM
welcome to the board!
I think about 7" wide is max for close to stock, IIRC maybe 8" on the rear. a search will tell you what I can't remember... I just wanted to welcome you! |
70Sixter |
Jun 25 2009, 03:24 PM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Yes, WELCOME!
And the max wheel size depends on several factors like offset (or the easier for me to understand - backspacing). Also tires of the same size do not always have the same dimensions. Offset is measure from the wheel center line. Backspace from the mounting surface to the inner rim. Lowered cars usually increase the likelihood of tires rubbing somewhere. The 7" 911R wheel probably works because the backspacing sets it inboard. I'd think normal 7s would be tough. But 914s are not all the same, nor even the same on left and right sides. |
carr914 |
Jun 25 2009, 06:48 PM
Racer from Birth Group: Members Posts: 118,626 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Yes, WELCOME! The 7" 911R wheel probably works because the backspacing sets it inboard. I'd think normal 7s would be tough. But a 911R wheel will cost more than a lot of 914s. Regular 7"s will work, but you can't go crazy wide on the tire, probably 205/50/15s T.C. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:58 PM |
