| SUNAB914 |
Jul 1 2009, 09:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Had to pull my motor to do some replacing of a few seals and some other small stuff, so I just wanted to find out what the best weight of motor oil I should use with my engine when I refill. New rebuild, with hydro lifters.
Thanks By the way, my 2.0l with single weber carb has been getting 26mpg average in city and my 1.8L plus upgrade, w/ duel webers has been getting 26-27mpg average. haven't put either on a good highway miles to find out what they can really get yet. I'd say that's pretty good. |
| Tom |
Jul 1 2009, 10:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Brad Penn 20w-50 gt1 racing oil. You can get it from Jack or somewhere local perhaps. My 2.0 liter with hydros seems to like it better. Not as much lifter noise if not run every day.
Tom |
| SUNAB914 |
Jul 1 2009, 12:06 PM
Thanks for that. Anyone else?
| Tom |
Jul 1 2009, 01:45 PM
I mean Jake Raby of Jake Raby Enterprises. Air cooled technologies, etc. Look up his website, he did a lot of testing on oils and highly recommends Brad Penn.
Tom |
| jk76.914 |
Jul 1 2009, 09:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I think 20W-50 is the "correct" weight for hydros. Keep the zinc and phosphorus up, and I understand Brad Penn does that and a lot of guys have a high regard for it.
After breakin back in 2004, I've run Mobil 1 V-Twin 20W-50 in my hydro D-jet 2.0L. It's designed for aircooled (motorcycles actually) so it has the Zn and P for our flat tappet lifters, so if you've considered a synthetic, this is a possibility. |
| SUNAB914 |
Jul 2 2009, 06:39 AM
Thanks again.
| 70Sixter |
Jul 3 2009, 11:41 AM
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Charles Navarro of LN Engineering also recommends Brad Penn. It is basically the old Kendall GT-1 updated from the old straight 30W we used to use in aircooleds.
A lot of oils have been reformulated with lower ZDDP levels mostly out of political correctness IMO. |
| sww914 |
Jul 3 2009, 02:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
My hydraulic lifters work a LOOOOOOOOOOOOT better with Brad Penn 20/50 than they did before.
| jk76.914 |
Jul 3 2009, 03:23 PM
| sww914 |
Jul 3 2009, 03:52 PM
I'm not sure what was in there, MarkB would know. I don't put tons of miles on the car so it took me awhile to get around to the oil change after I got the car, like almost a year. Bad Mechanic, no girly calenders for you!
Lo-Fi Version | Time is now: 7th March 2026 - 12:41 AM |
