914 speedometer removal, ..to preserve original mileage |
swm914 |
Jul 2 2009, 09:01 AM
Member Group: Members Posts: 82 Joined: 28-January 07 From: Palmyra, PA Member No.: 7,484 Region Association: None |
Hi, I need to remove the speedometer in my '74 914. The needle still works but both odometers stopped. I want to repair it and put it back in in order to preserve original mileage (54K)
What is the most efficient way to do so? Must I remove the steering wheel? Is this a simple procedure for a mechanically challenged 914 owner? Thanks Steve |
Porsche Rescue |
Jul 2 2009, 09:34 AM
This question might be best answered in the "Garage". But here's mine:
Easiest to remove the steering wheel, not certain if necessary, but I always do. Need large socket, 27mm or 1 1'16" I think. Gauges are held in by the rubber ring so you just pull them out. Take the tach out first, disconnect and mark/diagram the wires. Then reach in the vacant tach hole and unscrew the cable from the speedo. Pull it out, again taking care to remove and mark the wires. |
70Sixter |
Jul 3 2009, 11:35 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Mark the steering wheel location so reinstall will be easy to line up.
Repair is not simple for me or for a "mechanically challenged" owner. Getting the trim ring back on the speedo was the hardest part. Pelican has instructions IIRC. I'd send it to a shop for repair. Seems like a member here does it. If not North Hollywood has always done well for me in the past. |
Pat Garvey |
Jul 3 2009, 07:50 PM
Hi, I need to remove the speedometer in my '74 914. The needle still works but both odometers stopped. I want to repair it and put it back in in order to preserve original mileage (54K) What is the most efficient way to do so? Must I remove the steering wheel? Is this a simple procedure for a mechanically challenged 914 owner? Thanks Steve Steve, It's far easier to remove the wheel. And it's easy, and in they way. Grab the horn ring, push down, and turn it left. You'll reach a stop. Wiggle it a little & it'll come off. You'll be faced with a BIG nut(forget the dimensions - someone help out here). Before you remove the nut (did I say BIG) mark the top position of the spline with a red Sharpie, so you'll know where to re-position the wheel. Remove nut & wheel & you'll have much easier access to the speedo, which also comes out easily. On the speedo assy, push from the rear slightly, to remove it from the pod. Unscrew the sender , mark the indicator wires, remove the wires & pop it out the front. Easy. Send the speedo to Palo Alto, or someone else reputable. Have it taken apart cleaned & re-calibrated. Get it back - put it in in reverse order. Hint....while you're in there, you may want to do the same with the other instuments. They get fogged up over the years. Nevertheless, they all are easier to access if the wheel is removed - just be certain to mark the wheel position on the spline. Easy job, even for me! Pat |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:41 PM |
