Console Heater Defrost Lever ( SOLD ), Heater Defrost Lever almost Perfect !!! (SOLD) |
BarberDave |
Jul 4 2009, 02:47 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Hi : I just recieved and posted on E -BAY , item # 120444030741 a all most concour Heater Defrost Lever. Perfect for a show car. or a C W with a little work. No pictures here , because I can't figure out how, but can E-Bay. Take a look if your interested. Pat: If this is in the wrong area, please move to the right one. Dave (IMG:style_emoticons/default/slap.gif) |
Jul 4 2009, 03:46 PM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Tom_T |
Jul 4 2009, 05:45 PM
(IMG:style_emoticons/default/smilie_pokal.gif) Hi : I just recieved and posted on E -BAY , item # 120444030741 a all most concour Heater Defrost Lever. Perfect for a show car. or a C W with a little work. No pictures here , because I can't figure out how, but can E-Bay. Take a look if your interested. Pat: If this is in the wrong area, please move to the right one. Dave (IMG:style_emoticons/default/slap.gif) I need one & want one - how much? & shipping to 92867? Tom T Orange CA /////// |
sixerdon |
Jul 4 2009, 06:37 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Tom T & Dave, be careful. You both need to know that this is not correct for "all" 914's. Especially you, Tom. Do your homework on this. My sources say this is not for early '73's such as yours. Just thought I would help avoid a disappointment with both parties.
Don |
Tom_T |
Jul 4 2009, 06:49 PM
Tom T & Dave, be careful. You both need to know that this is not correct for "all" 914's. Especially you, Tom. Do your homework on this. My sources say this is not for early '73's such as yours. Just thought I would help avoid a disappointment with both parties. Don What's the difference Don & where do I find info on it??? Mine had the center console stripped by the dealer (along with fogs & Fuchs), so I rechecked & I have a straight lever, but understood that all with consoles needs the crooked-handle type to fit the console's slot? (IMG:style_emoticons/default/confused24.gif) Is there another type for on early consoles?? ....if so, may explain why mine is straight? (IMG:style_emoticons/default/idea.gif) |
BarberDave |
Jul 4 2009, 07:34 PM
Hay : Don it came from a 73. Are you refering to the tab for the heat defrost light . If so it is on the other side of the lever . The picture is 1 of the 2 in the add check it out it shows the other side. Dave (IMG:style_emoticons/default/slap.gif) |
MDG |
Jul 4 2009, 07:41 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
You've got it backwards, Tom. The straight lever like the one in the photo is for a '73-'76 console. The ones with the bend in them are for non-console cars.
m. |
BarberDave |
Jul 4 2009, 07:47 PM
If what Don , was talking about is that tab for the wire its on the other side , of the lever on the white plastic part. Tom, Mark it as sold, Right? Dave |
Tom_T |
Jul 5 2009, 02:55 PM
You've got it backwards, Tom. The straight lever like the one in the photo is for a '73-'76 console. The ones with the bend in them are for non-console cars. m. That's bass-ackwards from what I've always heard, & the Paternie 914 book shows the angled one as correct for the console in order to clear over to the slot in the console's floors????? (IMG:style_emoticons/default/confused24.gif) |
Tom_T |
Jul 5 2009, 03:13 PM
Okay folks - here's the straight lever & round red knob which has been on since 12/75, after the dealer selling to PO/OO had stripped out the center console, fog lights/switch & Fuchs for them! (IMG:style_emoticons/default/dry.gif)
BTW - that's 24+ years of dust - NOT rust, so it will clean up to perfect condition! (IMG:style_emoticons/default/smile.gif) According to Paternie's "How to Restore & Modify Your Porsche 914 & 914/6", the one Dave has is correct for my early-73 914-2L VIN.....1954. So, what's correct knob & lever???? (IMG:style_emoticons/default/confused24.gif) |
Tom_T |
Jul 5 2009, 03:31 PM
....and here's a pic of an OE console in an earlier 73 914-2L VIN....1102 & same 9/72 build date as mine with the round knob!
- but I cannot see if lever is straight or angled on either? as opposed to a squarish one on earlier cars - Pat Garvey, please confirm on your 72? (IMG:style_emoticons/default/confused24.gif) 73 914-2L VIN...1102 Console & Lever: Another 73 2L Third 73 2L all 3 appear to have rounded-tapered & round-top red knobs, but angled or straight lever unknown???? |
MDG |
Jul 5 2009, 06:09 PM
I am referring to the chrome shaft. The straight lever sildes up through the slot in the console, you screw on the red knob and the lever basically toggles straight back and forth.
The ones with the bend in that shaft are designed so when pushed to the forward OFF position it lays flat down against the carpeted tunnel. One with the bend in it will not go up through the slot in the console. Oh, and that pic you posted showing the lever pushed forward and down against your carpeted tunnel? That is not a straight lever as posted in that original photo. If it was it would be sticking up and forward at around 65 degrees. Trust me, both cars I own have consoles, both have the straight lever. The photo at the bottom of page 56 of the Paternie book clearly shows this. |
MDG |
Jul 5 2009, 07:17 PM
MDG |
Jul 5 2009, 07:34 PM
Tom, the simple way to see the difference is download a copy of George's catalogue if you haven't already - great reference tool BTW. Page 79 shows the 2 levers used in 914's. The straight shaft for the console cars, the bent shaft used in the non-console cars (like the one in your pic).
George also show a bent shaft for '72 with 'Defrost Emblem'; Pat or George may weigh in and explain that one. Was there something unique for '72 with the lever and defrost emblem (IMG:style_emoticons/default/confused24.gif) |
Pat Garvey |
Jul 5 2009, 07:39 PM
You've got it backwards, Tom. The straight lever like the one in the photo is for a '73-'76 console. The ones with the bend in them are for non-console cars. m. Agree. Bent lever , no console (of course) for my 72 914. Now, this is where it gets interesting. My 72 914 has a bend, as well as the knob pictured. My 73 T (a late year model, w/CIS) has the same knob, but a straight lever. Both cars are original. These are both push-on, not screw on. Oh, the Porsche spooks strike again! Pat Attached thumbnail(s) |
MDG |
Jul 5 2009, 07:42 PM
Ha! If I have waited 5 minutes for Pat to post that pic I would have had my answer to the "unique for '72" lever in George's catalogue. I guess the knob on the '72s with the printing on them is in lieu of the lighted on/off box? Do the '72s not have them - can't tell from Pat's photo.
Tom_T |
Jul 5 2009, 08:23 PM
Okay All Y'all - I've looked at uncle georgie's catalog pp. 76, and this above looks like the #1 for the console part #U914 424 073 02. It appears that the lazy-Zee bend back over the mount is the "angle" shown on Paternie pp. 56 & above & at AA's parts catalog, & those straight up from the mount (no angle back to the left) is non-console. Are we confusing in this discussion - the "bend-over" angle (IMG:style_emoticons/default/bootyshake.gif) (sorry - couldn't resist) front to back on the lever in the same plane as the lever moves front to back; - with the bend to the left, then bend back vertical perpendicular to the travel of the lever? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/confused24.gif) I think this "angle" thing has everybody going off in opposite directions! (IMG:style_emoticons/default/idea.gif) I'd have to skinny into mine again to see if it has that fold over "flat Z bend" like the above, but I don't think so. I may try before it gets dark. |
sixerdon |
Jul 5 2009, 09:03 PM
Now, "Authenticity" suggests that the '72 knob was carried over to "early '73. The question now becomes,..... if it did, how early?
Thanks for showing the alternate knob, Pat. Don |
MDG |
Jul 5 2009, 09:17 PM
Tom, as I said, I am talking about the 'shaft' of the lever - straight for console; bent for non-console.
The straight console lever is offset near it's base; I believe this offset is what you are referring to as a 'bend'. If you look near the mount of the straight console lever, the offset is there so it lines up with the slot in the console. I am 99.9% certain there are no early or late versions of this; if the car came with a console it came with this lever. 1973. 1974. 1975. 1976. |
Tom_T |
Jul 5 2009, 10:34 PM
Now, "Authenticity" suggests that the '72 knob was carried over to "early '73. The question now becomes,..... if it did, how early? Thanks for showing the alternate knob, Pat. Don My current knob & the first console example which I posted above which is same build month but 852 before mine (200+/- 2.0s prior) both are not as per Pat's & AA catalog lists 72 MY only. So they were back to the round screw on style by Sept. 72. If there was a carry-over, it stopped before my #1954 & before #1102. After rereading these posts - I'm sure this above "angle/bend discussion" is a confusion of terms between the "sweeping bend" which you see when looking at the flat face of the lever; and the 2 x 90 degree angle bends up-to-left then back left-to-up when looking at the thin end of the lever. For clarification, when I said "angled lever" above in all cases - I was referring to the latter. I wasn't even thinking of nor really noticing that the console style one goes straight up thru the console's slot in the bottom panel. |
Lo-Fi Version | Time is now: 4th May 2024 - 10:00 AM |
