> are these valves bad?, picture attached.
JOE M
post Jul 5 2009, 10:31 AM
Rich,
I tried to add a pic in a p.m I sent you but could not do it. Can anyone tell me if looking at this pic there is an indication if the valves are burned or bad?The car has low compression and is near impossible to tune.The pic is of cylinders 1 and 2. Thanks.
2 Pages V < 1 2
Replies(20 - 23)
JOE M
post Jul 5 2009, 07:04 PM
Post #21
Thats what led me to trying to remove the heads with the engine in. I do not have the proper tools.
QUOTE(dakotaewing @ Jul 5 2009, 05:43 PM) *
QUOTE(JOE M @ Jul 5 2009, 07:35 PM) *
QUOTE(r_towle @ Jul 5 2009, 04:44 PM) *
While you are on it...
Get the shifter rod off.
Remove the clutch cable and the speedo cable...bend gently towards the front of the car and under the car...no kinking.
Pull the throttle cable down below and put it with the clutch cable.
From there...30 minutes and two beers...we are done.
Rich
OK Rich I will get the cables out and the shift rod. What kind of beer do you like?Im on this kick where i have been drinking misro brews.But I like any beer. So tomorrow I will get all the cables and linkage off.
Make sure to disconnect the axles/CV's at the tranny while you are at it, if you have the proper tools...
If you don't have the proper tools, wait on Rich... (IMG:style_emoticons/default/blink.gif)
JOE M
post Jul 6 2009, 04:20 PM
Post #22
Rich
O.K I got all the cables and the shift linkage out.I put some liquid wrench on the transmission mount bolts.They were heavily rusted so I figured it was something that would help. Other than what kind of beer you like ,anything else I need to do? I do not have a dolly.
r_towle
post Jul 6 2009, 05:07 PM
Post #23
Custom Member
I could do this tomorrow if you want....its supposed to rain on Wednesday...and seeing as you have no roof (hint hint)
Tuesday would be better.
I will bring a dolly, and the tools we need to drop it.
Make sure the carbs are off (to high) and put tape over the manifolds...
Or...I bet you removed all that already...so dont worry...
Remove and cap the fuel lines so we dont get all wet....
thats it...
IDK about the beer...your choice.
Rich
JOE M
post Jul 6 2009, 06:18 PM
Post #24
Thanks sounds good.
QUOTE(r_towle @ Jul 6 2009, 04:07 PM) *
thats it...
Rich
2 Pages V < 1 2
- Lo-Fi Version Time is now: 31st July 2025 - 09:38 AM
