> How do you use an End Play tool
VaccaRabite
post Jul 11 2009, 07:33 AM
En Garde!
I got an end play tool, and I can't figure out how it works.
It clearly bolts to the flange, I am guessing over the flywheel. But how do you use it to measure flywheel endplay? It just came with the tool, no instructions.
Zach
VaccaRabite
post Jul 11 2009, 07:34 AM
En Garde!
One of these tools:
(IMG:http://www.chircoestore.com/catalog/images/012107.jpg)
jimkelly
post Jul 11 2009, 07:47 AM
Delaware USA
i think you put a guage on it and mount it to the block - with the guage touching the end of the crank. to measure the play in the crank with flywheel not yet installed? by tapping lightly on the ends on the crank - in order to determine if you have enough shims in there?? maybe with yours you just use a feeler guage or mic to measure gap??
qa1142
post Jul 11 2009, 07:55 AM
Whiplash
tap flywheel towards the tool.
set the bold to just touch flywheel.
Tap play the other direction and measure the gap with feeler gauges
URY914
post Jul 11 2009, 11:32 AM
endplaytool.com
VaccaRabite
post Jul 11 2009, 12:58 PM
En Garde!
QUOTE(qa1142 @ Jul 11 2009, 08:55 AM) *
Ah-HAH!
Thanks
Zach
ME733
post Jul 11 2009, 01:25 PM
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) Its the feeler guage type of end play tool. (IMG:style_emoticons/default/bye1.gif)
charliew
post Jul 11 2009, 04:41 PM
It's for guys that only use feeler gauges. If you can get a dial indicator mounted it is really easier to use. The feeler gauge is as most know a matter of feel and tight to one is not tight to another and if any lubricant is involved is really a relative thing sorta like another thing about tight or loose and the amount of lubrication needed. Course the tighter it is the harder it is to get it in, er the gauge.
aircooledtechguy
post Jul 12 2009, 01:22 PM
The Aircooledtech Guy
Actually the new end-play tools like the one pictured have a 1.0mm thread pitch on the screw, so each 1/4 turn is .25mm. No feeler gauges needed.
I've never trusted that though. I use a dial indicator exclusively on my motor builds.
- Lo-Fi Version Time is now: 30th July 2025 - 08:59 PM
