Rustoration 101, Getting started on iron ozide removal |
East coaster |
Mar 6 2004, 06:56 AM
Senior Member Group: Members Posts: 1,679 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Decided to dig into the rusted areas of my 3.6 project. It's not too bad, but the jack posts are junk and there's a couple holes in the firewall. Here's what's left of passenger side jackpost laying on my floor!
Attached File(s) DSC00023.JPE ( 15.38k ) Number of downloads: 0 |
East coaster |
Mar 6 2004, 07:02 AM
Here's one half way through the clean up process. I've got it down to clean metal now and I'm really going back and forth on whether to replace the jack post (I aready have the parts) or delete the jack post and just weld a flat plate across this area and remove the possibility of dirt collecting here again. I've owned about 7 914's and I can't say I've ever jacked one up using this post. I'll probably flip a coin......heads )jack post), tails (plate). (IMG:style_emoticons/default/confused24.gif)
Attached File(s) DSC00024.JPE ( 15.06k ) Number of downloads: 0 |
East coaster |
Mar 6 2004, 07:04 AM
Here's the firewall spots....Not bad a couple of butt welded plated and it never happened.
Attached File(s) DSC00025.JPE ( 15.05k ) Number of downloads: 0 |
East coaster |
Mar 6 2004, 07:05 AM
The drivers side jack post before pic.......
Attached File(s) DSC00026.JPE ( 15.05k ) Number of downloads: 0 |
East coaster |
Mar 6 2004, 06:04 PM
Well, I flipped a coin and it came up heads! Here's the new jack post welded in and primed. A good way to kill an afternoon!
Attached File(s) DSC00027.JPE ( 14.46k ) Number of downloads: 0 |
East coaster |
Another........
Attached File(s) DSC00028.JPE ( 14.77k ) Number of downloads: 0 |
echocanyons |
Mar 6 2004, 06:05 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Nice job!
East coaster |
Mar 6 2004, 06:07 PM
Here's a patch butt welded into the firewall behind drivers seat. I've got two more to do behind passenger seat and then the other jack post and the rust will be history!
Attached File(s) DSC00029.JPE ( 15.03k ) Number of downloads: 0 |
TimT |
Mar 6 2004, 06:09 PM
Dude and you live by the sea?
nice job... |
trojanhorsepower |
Mar 6 2004, 10:14 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
East Coaster
How did you weld the top of your jack post with out cutting out the rear fender? I have cut out my old jack post and fixed the long underneath, but I do not see a good way to weld the top part of the jack post when I put it back in. Any tips? Thanks -Pete |
Gint |
Mar 6 2004, 10:34 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Good work. (IMG:style_emoticons/default/welder.gif)
East coaster |
Mar 7 2004, 02:31 AM
Pete, Yeah....I wondered how the hell anybody welds the top of the jackpost without having the fender off. What I finally did was to contort myself into the fender well and using my trusty hammer I made sure the top of the bracket was fitted well to the long. Then I took my mig tip and placed it as close to the front as possible (basically touching the door jamb) and closing my eyes (no room for a helmet), blindly stitched it shut. What pissed me off was that some of the best welds on this project were done with my eyes closed! I welded about 1/4", stopped, made sure I was on track and started again until I made it front to back. There is still about 1/2" at the front I just couldn't get to because of the door jamb, but seeing how the factory had about 4 plug welds holding it I think it will be just fine. Even though it only took a day to do, I'm not really looking forward to the other side. Good luck with yours! Post pics!
IronHillRestorations |
Mar 8 2004, 12:32 PM
I. I. R. C. Group: Members Posts: 6,722 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
It helps to have small hands!
HTP ph# WELDUSA makes an adjustable swan's neck for mig welders, a very handy thing to have for restoration/rustoration work. Just don't forget to do PK's Chassis Corrosion Treatment after doing all your welding. PK (IMG:style_emoticons/default/cool.gif) |
East coaster |
Mar 8 2004, 06:48 PM
Huh?? |
Bleyseng |
Mar 8 2004, 08:22 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yeah Perry, post that tech article on the long treatment you did a few years ago. It was great!
Geoff |
Lo-Fi Version | Time is now: 26th May 2024 - 07:01 AM |
