Throttle Body 1.7 DJet -- Stock screw setting? |
kpfoten |
Jul 13 2009, 08:59 AM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
Hi, Was wondering if there was a stock setting for the idle screw on the throttle body of a 1.7 Djet? Just want to make sure it's in the right spot... (i.e. all the way clockwise and then counterclockwise two full turns) |
type47 |
Jul 13 2009, 03:48 PM
I don't think there is a stock setting, just a correct setting.
JoeSharp |
Jul 13 2009, 05:50 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The idle screw is supposed to control the idle speed. If it does not control the idle you prolly have a vacume leak.
Rand |
Jul 13 2009, 05:53 PM
If the fuel mixture is set correctly on the ECU, and the knob on the throttle body affects idle speed as you turn it, just dial it in to <900rpms or so and be done. :-)
Pat Garvey |
Jul 13 2009, 07:26 PM
Millerwelds |
Jul 13 2009, 08:17 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
If the fuel mixture is set correctly on the ECU, and the knob on the throttle body affects idle speed as you turn it, just dial it in to <900rpms or so and be done. :-) Right On! Alright, newbie question: How do you know if the fuel mixture setting is correct? And is that the starting point for tuning or do you start with adjusting the valves, check timing, etc? (IMG:style_emoticons/default/huh.gif) |
orange914 |
Jul 13 2009, 10:49 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Alright, newbie question: How do you know if the fuel mixture setting is correct? And is that the starting point for tuning or do you start with adjusting the valves, check timing, etc? (IMG:style_emoticons/default/huh.gif) valves first... incorrect settings will effect driveability/idle quality/speed |
kpfoten |
Jul 14 2009, 07:57 AM
Great! Thanks. I dialed it down. The car idles great. BTW, always check your points (if you have 'em) -- I got a bum set of Bosch points (the faces weren't mating square). I wonder if I can bend them back in place? Anyway, I got a set of non-Bosch from my FLAPS which should hold me over... Now for the fine tuning. I've got a Gunson analyzer so hopefully I should be able to get the mix just right... |
Lo-Fi Version | Time is now: 18th May 2024 - 08:52 AM |
