Crank Position Sensor, for stock cooling engines |
McMark |
Jul 13 2009, 10:11 AM
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else. (IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg) |
McMark |
Jan 22 2010, 12:43 AM
My system only works with MegaSquirt for sure. It's the only one I've tested it with. And SDS/Magnet wheel is a completely different animal, and I haven't had time to research the components.
underthetire |
Jan 22 2010, 10:17 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
My system only works with MegaSquirt for sure. It's the only one I've tested it with. And SDS/Magnet wheel is a completely different animal, and I haven't had time to research the components. So, if you have used the megasquirt with this, you would have all the ignition parameters as well ? Could these be provided? I'm getting a little closer to needing one, but I would not want wires soldered and filled. I can get the connector from my neighbor or DIY auto. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:33 PM |
