Crank Position Sensor, for stock cooling engines |
McMark |
Jul 13 2009, 10:11 AM
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else. (IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg) |
McMark |
Nov 10 2010, 01:54 PM
They are still available. I'm having more wheels machined right now, so they're a couple weeks out. But they are still available.
The sensor is from a Subaru. I would LOVE to find a connector for it, but haven't been able to so far. If you can find one, let me know. |
arvcube |
Nov 10 2010, 04:16 PM
Member Group: Members Posts: 170 Joined: 25-September 07 From: poway, ca Member No.: 8,147 |
They are still available. I'm having more wheels machined right now, so they're a couple weeks out. But they are still available. The sensor is from a Subaru. I would LOVE to find a connector for it, but haven't been able to so far. If you can find one, let me know. Let me know when the next one is available. I'm ready to paypal. I'll also look for a pigtail. have a p/n on that sensor by any chance? thanks, arvin |
Lo-Fi Version | Time is now: 17th May 2024 - 09:08 PM |
