Crank Position Sensor, for stock cooling engines |
McMark |
Jul 13 2009, 10:11 AM
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else. (IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg) |
914werke |
Dec 17 2010, 03:04 AM
"I got blisters on me fingers" Group: Members Posts: 10,066 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Rob needs one now too, and his motor is here at the shop. So a solution is imminent. (IMG:style_emoticons/default/thumb3d.gif) Any Update? (IMG:style_emoticons/default/smile.gif) |
ConeDodger |
Dec 17 2010, 06:15 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Rob needs one now too, and his motor is here at the shop. So a solution is imminent. (IMG:style_emoticons/default/thumb3d.gif) Any Update? (IMG:style_emoticons/default/smile.gif) I was unable to use Mark's trigger wheel as it is incompatible with SDS at this point in time. There may be a solution out there but for the sake of expediency, I went with a Hall Sensor set up from SDS. Oh, and I am the Rob of which he speaks... |
Lo-Fi Version | Time is now: 17th May 2024 - 08:11 PM |
