Crank Position Sensor, for stock cooling engines |
McMark |
Jul 13 2009, 10:11 AM
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else. (IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg) |
McMark |
May 20 2011, 02:02 PM
I happen to have a DTM equipped engine in the shop right now. I'll take some pictures and send details.
914Mike |
May 23 2011, 12:54 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
I happen to have a DTM equipped engine in the shop right now. I'll take some pictures and send details. Inquiring minds want to know! Post here so we can all see, I for one will be putting a 1.8 in my Ghia soon. I didn't leave any room for the spacer when I made my pulley, but it's really just a matter of where the alternator pulley sits. If you are making your own alt stand & sheet metal bits it can be made to work. I was planning on buying the DTM, so really would like to know if it can line up. TIA! |
Lo-Fi Version | Time is now: 17th May 2024 - 07:38 PM |
