Crank Position Sensor, for stock cooling engines |
McMark |
Jul 13 2009, 10:11 AM
Since quite a few people were interested in crank fire and aftermarket FI system I finally finished up my crank position sensor setup. So if you want to run distributor-less ignition or modern FI, this setup is the ONLY setup built specifically to bolt onto a Type 4.
It's a complete bolt on upgrade, which means no drilling or modifying any parts to make this work. Only the cooling fan needs to be removed to complete the installation. This setup is great for modern FI system, which need a 'trigger signal'. Fuel only setups usually get their signal from the coil firing, but that signal is DIRTY and unreliable. This crank fire setup is smooth and clean. You can't beat it. There is no other setup built specifically for our motors. Quick easy installation with no headaches. Complete package price is $175 and includes the trigger wheel, the sensor w/ connector (pigtail or uncrimped), and the mounting bracket. You won't need to go searching for anything else. (IMG:http://www.914world.com/bbs2/uploads/post-419-1244942673.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-419-1245008370.jpg) |
McMark |
Jan 23 2012, 02:23 PM
Flash, I haven't had time to set up my web-store. I have one more coil mount setup in stock and one more trigger wheel setup in stock. But I'm always making more, so they will be available in the future.
draganc |
Jan 25 2012, 09:56 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Flash, I haven't had time to set up my web-store. I have one more coil mount setup in stock and one more trigger wheel setup in stock. But I'm always making more, so they will be available in the future. Mark, I would take the coil mount in case Flash is not interested anymore. If too late, when can you have another coil mount avalibel? Please PM with the price and I will send you the funds via paypal. Thanks, Dragan PS: your trigger wheels fits perfect. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:06 PM |
