SS HEs - Can I weld ends to plug this up?, ...the open ends of the outer heater shroud? |
Tom_T |
Jul 14 2009, 02:20 AM
A couple of Techie questions on Stainless HEs, since I need to have one of the manifold lug ears welded anyway...
1. Can I have the welder close off the ends of the heat shroud at the front & rear of the HE around the exhaust pipes?? (IMG:style_emoticons/default/confused24.gif) They don't appear to need to be open for air flow to the cabin heater loop, but are notorious places for exhaust gas & oil spatter to get in & (IMG:style_emoticons/default/icon8.gif) 2. What's the best way to have the welder replace the mild steel end flanges at the muffler (which are welded in), with the new SS flanges from Engman - so I don't end up too short for the 2L muffler bracket position?? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/idea.gif) |
Mark Henry |
Jul 14 2009, 05:41 AM
Easy way to line things up is to bolt everything including the (stock) muffler togetther, Still won't perferct so it may need some tweaking, bending, clamps, etc.
If you use the stock muffler it should keep things straight. Tack it up then take it off and weld. I have an old jig engine (empty block, just old cylinders and heads w/good exhaust studs) and a scrap trans, that I set upside down for a jig. You shouldn't need to weld up the seams, if you smell exhaust you have an exhaust leak....just like if the cab is filling with smoke you have an oil leak. Welding the clamshell may be tricky as it's very thin SS. |
jimkelly |
Jul 14 2009, 07:00 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i am curious to see how the flange replacement goes and cost??
i would think you would at least want to mount them to a scrap head - to keep the lined up as the tin won't help much. jim |
Jul 14 2009, 11:01 AM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
1. Can I have the welder close off the ends of the heat shroud at the front & rear of the HE around the exhaust pipes?? (IMG:style_emoticons/default/confused24.gif) They are not welded for a reason ... To keep you alive ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Tom_T |
Jul 14 2009, 12:48 PM
1. Can I have the welder close off the ends of the heat shroud at the front & rear of the HE around the exhaust pipes?? (IMG:style_emoticons/default/confused24.gif) They are not welded for a reason ... To keep you alive ... (IMG:style_emoticons/default/popcorn[1].gif) Andy How so Andy? (IMG:style_emoticons/default/confused24.gif) ...please educate me! (IMG:style_emoticons/default/popcorn[1].gif) I had assumed that they were not closed off like the sides are because of cost/difficulty reasons only, since the warmed fresh air-flow comes in one pipe & out another, & those open ends don't appear to serve a purpose in that scheme. However, I see the point Mark is making above - as to the difficulty in welding the thin shroud SS sheetmetal to the thin sheetmetal exhaust pipes. The other option which I considered was that aluminum exhaust tape to close them off, but I thought that having the welder close them off with the rod material would be the better solution, since I need one ear repaired anyway, so it wouldn't add much to that cost if done at the same time. (IMG:style_emoticons/default/confused24.gif) |
Tom_T |
Jul 14 2009, 12:58 PM
i am curious to see how the flange replacement goes and cost?? i would think you would at least want to mount them to a scrap head - to keep the lined up as the tin won't help much. jim The SS Flanges are $29.95 each side + Welding TBD, which I won't be doing myself. No skills/experience in (IMG:style_emoticons/default/welder.gif) - nor the equipment! I try to know my limitations! (IMG:style_emoticons/default/biggrin.gif) Since the engine & transaxle will need to come out for repairing, restoring & repainting the body shell, it could be set up on the actual engine & flanges. I just wasn't sure whether to just have the pipes cut-off at the inside of the old flanges, or to cut the flanges off the pipes to preserve the length of the pipes - if that's even possible?? (IMG:style_emoticons/default/confused24.gif) BTW ALL - These are used 2L SS HE's which I picked up because my 36+ year old OE ones are now rusted out & need to come off. So they've never been "fit" to my 2L engine & muffler on the car. |
charliew |
Jul 14 2009, 01:04 PM
They are probably not welded because of the additional cost of the welding labor. I don't see why it's necessary unless the heater doesn't get warm enough. Stuff getting in is as bad as moisture that can't get out. I'm sure there is some condensation there. When you weld ss tubing it will twist and warp pretty bad unless you go real slow. Also there may be a different expansion and contraction length between the two pieces when the exhaust gets hot and the loose ends allow for the different lengths. The movement might be observeable on the tubing.
I do know that long ss exhaust does grow quite a bit on bigger cars. The only way I see to keep the exact same length is to cut the welds loose inside the old flange and hope the tubing is still good enough to weld the new flanges to. I would think it all needs to be bolted together to get it to align back up. As in the whole car, motor, and muffler unless you have the motor, tranny combo as someone has already mentioned. |
Tom_T |
Jul 14 2009, 01:21 PM
Easy way to line things up is to bolt everything including the (stock) muffler togetther, Still won't perferct so it may need some tweaking, bending, clamps, etc. If you use the stock muffler it should keep things straight. Tack it up then take it off and weld. I have an old jig engine (empty block, just old cylinders and heads w/good exhaust studs) and a scrap trans, that I set upside down for a jig. You shouldn't need to weld up the seams, if you smell exhaust you have an exhaust leak....just like if the cab is filling with smoke you have an oil leak. Welding the clamshell may be tricky as it's very thin SS. Thanx for the tip - as noted in reply to Andy, the engine & transaxle will be out, so it can serve as the jig. The reason I want to seal them off, is that every time a small oil leak comes up - & all 914s eventually get them, it gets sucked/thrown into those gaps then cruds them up, as can be seen in what the seller hasn't cleaned up on this used set before selling it to me! Also, small amounts of exhaust gases get sucked in there via the airstream, which can be enough to give mild cases of carbon-monoxide poisoning. If you've ever had headaches while driving your 914 when using the heater, that's why! According to my long time factory trained 914 mechanic Hans in Huntington Beach CA, that was always one of the biggest complaint he had from 914 owners, along with oil leaks! Looking at the current state of my OE HE's now - mine was probably starting by the time I put it into storage in my SoCal garage in 5/85, but our warmer climate probably saved me form having to use them much! (IMG:style_emoticons/default/blink.gif) This is the end of one - all 4 ends are bad + holed along the shroud at several places! Although the SS shouldn't rust away like these end, I do want to eliminate the gaps if I can & it's safe to do so. One end of one OE HE: (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif) |
Tom_T |
Jul 14 2009, 01:29 PM
Can't find now who asked "...why replace the flanges?" - but the pic of one of the mild steel flanges on the SS HEs above, clearly shows that it has been rusting away where the pitting shows, but the seller wire-wheeled everything to clean up the HEs - so they now "look" nice-n-shiny. (IMG:style_emoticons/default/huh.gif)
Since I'm putting so much into repairing/restoring my early73 2L, & that everything is coming off to do so anyway, & that I need one mounting lobe/ear repaired/welded at a crack - I might as well get this right now, so it will all last another 30 years without trouble! (IMG:style_emoticons/default/smile.gif) Same idea on using SS HEs - rather than OE carbon steel ones, as well as why I want those ends sealed up - if it's not otherwise a problem/safety issue (pending "Sir Andy's" answer/clarification)! So that's my story anyway, & I'm stickin' to it! (IMG:style_emoticons/default/biggrin.gif) |
Todd Enlund |
Jul 14 2009, 01:45 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
They are not welded for a reason ... To keep you alive ... (IMG:style_emoticons/default/popcorn[1].gif) Andy How so Andy? (IMG:style_emoticons/default/confused24.gif) ...please educate me! (IMG:style_emoticons/default/popcorn[1].gif) I think Andy's point is that weld beads can crack, and a crack lets CO into the cabin. |
Tom_T |
Jul 14 2009, 01:52 PM
They are probably not welded because of the additional cost of the welding labor. I don't see why it's necessary unless the heater doesn't get warm enough. Stuff getting in is as bad as moisture that can't get out. I'm sure there is some condensation there. When you weld ss tubing it will twist and warp pretty bad unless you go real slow. Also there may be a different expansion and contraction length between the two pieces when the exhaust gets hot and the loose ends allow for the different lengths. The movement might be observeable on the tubing. I do know that long ss exhaust does grow quite a bit on bigger cars. The only way I see to keep the exact same length is to cut the welds loose inside the old flange and hope the tubing is still good enough to weld the new flanges to. I would think it all needs to be bolted together to get it to align back up. As in the whole car, motor, and muffler unless you have the motor, tranny combo as someone has already mentioned. Thanx Charlie - all good points on why the ends are left "loose"! (IMG:style_emoticons/default/smile.gif) As I said, the engine/tranny unit will be out of the car for some time - so it could be used as a jig to weld the flanges. Also, the new SS flanges appear to be a bit thicker - leaving some wiggle room. And you may have stumbled upon a replacement implant solution for guys needing Viagra in your second point!? ....just imagine an SS "Tool" that grows when you get "Hot"!!!! (IMG:style_emoticons/default/laugh.gif) |
jimkelly |
Jul 14 2009, 02:34 PM
i have a set that was welded as you are contemplating - see pic
Tom_T |
Jul 14 2009, 02:58 PM
Thanx Jim! (IMG:style_emoticons/default/smile.gif)
How did that work for you? I don't know if there is a difference in SS vs. carbon-steel expansion rates to cause the cracking noted above? (IMG:style_emoticons/default/confused24.gif) |
Todd Enlund |
Jul 14 2009, 03:34 PM
Thanx Jim! (IMG:style_emoticons/default/smile.gif) How did that work for you? I don't know if there is a difference in SS vs. carbon-steel expansion rates to cause the cracking noted above? (IMG:style_emoticons/default/confused24.gif) Not just expansion rates... a weld bead introduces a stress riser, and over time, vibration can cause a crack. Hydrogen embrittlement due to the weld is also a possible cause of cracking. I don't know how likely a crack is, but the possibility is there. |
ruddyboys |
Jul 14 2009, 04:04 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Just my two cents, the flanges do have some pits, could you grind of file flat, the gasket should then take care of any leaks?
jimkelly |
Jul 14 2009, 04:39 PM
i did not have them welded and never had them on a car - my cars don't have heat plumbed anyway - but i agree - if you flanges are not paper thin ( and thye don't look thin at all ) they should be ok with gaskets and some copper permatex - no need to grind them off - really.
jim Thanx Jim! (IMG:style_emoticons/default/smile.gif) How did that work for you? I don't know if there is a difference in SS vs. carbon-steel expansion rates to cause the cracking noted above? (IMG:style_emoticons/default/confused24.gif) |
Tom_T |
Jul 14 2009, 07:06 PM
Good input on both the flanges & ends sealing questions guys! (IMG:style_emoticons/default/beerchug.gif)
I think I'll take it up further when I get it over to my mechanic & may not do either, or only what's best. In any case, it sounds like the hi-temp aluminum tape which can flex may be the answer to sealing the end gaps, since it can flex - so long as there isn't some metals' interaction problem with them! (IMG:style_emoticons/default/idea.gif) I look at that type of reaction, after the head corrosion problems on the 2.1L Vanagon Water-boxer heads on our 88 Westy! (IMG:style_emoticons/default/dry.gif) |
Pat Garvey |
Jul 14 2009, 07:19 PM
They are not welded for a reason ... To keep you alive ... (IMG:style_emoticons/default/popcorn[1].gif) Andy How so Andy? (IMG:style_emoticons/default/confused24.gif) ...please educate me! (IMG:style_emoticons/default/popcorn[1].gif) I think Andy's point is that weld beads can crack, and a crack lets CO into the cabin. And I agree with Andy. With the flex that occurs in the whoe exhaust sytem, cracks are bound to happen. Will CO sneak in? Could be. I would leave it alone. My SSI's are 35 years old. Yeppir, there is some degredation of the red sealing compound they originally used on the ends. Until the shell rattles I'll leave them alone. Pat |
charliew |
Jul 14 2009, 10:20 PM
You know I just now remembered when we changed the headers on my sons sti we used a red high heat sealer on the flanges to help seal them as they didn't look exactly parallel with the head surface. That stuff would probably work on the ss shell to pipe surface and would probably stay in place if the surfaces were cleaned real good.
Tom_T |
Jul 14 2009, 10:48 PM
They are not welded for a reason ... To keep you alive ... (IMG:style_emoticons/default/popcorn[1].gif) Andy How so Andy? (IMG:style_emoticons/default/confused24.gif) ...please educate me! (IMG:style_emoticons/default/popcorn[1].gif) I think Andy's point is that weld beads can crack, and a crack lets CO into the cabin. And I agree with Andy. With the flex that occurs in the whoe exhaust sytem, cracks are bound to happen. Will CO sneak in? Could be. I would leave it alone. My SSI's are 35 years old. Yeppir, there is some degredation of the red sealing compound they originally used on the ends. Until the shell rattles I'll leave them alone. Pat Aha! So mine apparently has lost the red sealing compound at some point, or it got cleaned out with the wire wheel by seller. So I can follow the suggestion above of using the Red Heat Sealer, to recreate what Pat's talking about! (IMG:style_emoticons/default/beerchug.gif) So long as I'm essentially tearing apart & rebuilding this car, I might as well see that it's correct going in to start with, rather than just putting stuff back in a "half-fast" job! Anyone Recognize the brand of these?? Don't know if they're SSI's or another mfgr., and seller didn't know either - since got them with a couple of boxes of parts for a 2L core engine taken apart. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 04:04 AM |
